Recieved a box today containing my R33 calipers!
Got all the lines, shims and clips, and as a bonus what appear to be a virtually brand new set of brake pads :thumbsup:
Now for some offset brackets & bigger rotors.
There not r33 gtr brembo's are they?
No mate, sadly my finances don't run to Brembo's unfortunately, but I think the R33GTSt calipers teamed with this;
http://www.conceptzp...40203.166.28.81
I should have more than enough brake power.:thumbsup:
agreed, the brembos are about 10% more braking at 100% more cost. no worth it. 32 gtr/33 gtst are excellent for the price
Interested to hear how you get on with these brackets. I have tried several on my C34 without being able to fit them (very different from Skylines) although I see you have an M35 - lets hope they are the same as 350Z.
well this weekends pretty big for me now..
changed the spark plugs, to find that when i bought the car they had put iridiums in already :D SSV did a good compliance!
phenolic runner spacer.
suction pipe thats scotts making up.
then injectors are going in, and Cihan the tuner is coming around on monday to install my emanage, and dump the stock tune on it with bigger injectors..
just untill another couple of weeks before i can tune the bugger..
Craig- guess we are gonna try beat eachother now hahah
So are you tuning next weekend as well then? That's OK bud......I will enjoy the tear's I'll be seeing on your face when I blow your result's to the weed's...lol!
Yeh they will be fine...basically the same as what I am running atm!
Yeah, I had an R32 GTR setup on my r31, and that kicked arse, so I just wanted the bigger rotors to counteract the additional weight.
^ what the bolt size on those? wouldn't they have both holes drilled for the smaller size bolts?
I get so confused...:wacko:
Yep, but I'll be drilling out the M12 hub bolt holes & retapping for the M14 bolts from the original M35 calipers.
Alternatively, you could just use the bolts that come with the kit and use a sleeve inside the hub bores to take up the gap. Not too keen to do that with the additional bracket though.
Edited by Daleo
I dunno yet man. Might just wait a fortnight coz i still gotta get the boost sensor. U probably will with the bigger turbo I seriously don't know what to expect anymore. Hopefully more than 250 on e85
Lol....just toying with yah...250 is the figure I am after with normal unleaded.
Dale, where are you getting the adapters for the bigger rotors from?
I keep looking at the ones on ebay in the US for the S14 and the Z32 and wondering if these will work?
Do you have any idea if these will fit our car?
Cheers
Andy
Disassembled my 'stock' seats to remove the airbag sensors today, drivers side had the plug snipped from and when I went to directly wire it in I noticed the wiring on the plugs looked a little odd.. Id say the drivers side has the 2.2 OHM resistor between the wires (couldnt take it apart - the unit was covered in heat shrink and was 'boxy' so I guess they heat shrunk around a small plastic box which contains the resistor connecting the two plugs)! But I was able to plug the passenger side back in, so Ive secured that to the seat and reset the airbag light. Now I get to play the waiting game to see if the blinky light returns :domokun:
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
