Hey Ben, any word if those holes weaken the bar excessively?
It looks good and should send more air towards the cooler. Very nice.
BTW, where did you pick up the inserts?
yeah, i didn't realise renaults could go so well :D
its funny you should mention that. i was removing some parts from the wreck today. no nissan branding on them. there was renault tho lol
Im sure it must loose some strength... hopefully not too much!
Picked up the inserts from Just Jap $165 Link HERE
Make sure you use R33 inserts not R32 as they have different curves on the insert lip
un opened motor on BP Ultimate.....oh and 15-16psi!
nice result.... query - what size injectors?
my rb25 with 3076IW runs S15 450cc injectors, around 85% duty cycle for 250@wheels. thinking if I add in 550's would get a similar result to yours.
the 370's stockies maxed at 225kw@wheels
The start isn't conclusive as the torque converter isn't locked and the car will kick back if not at a certain speed. You can see the converter locking as the dip at the start.
Rev limit is set at 7200 but they usually shift by 6500 anyway.
Not bad for a GT3071 in the stock housings, Garret .82 wont do that much better, its down around 10kw less than their housings by the looks of it.
May have to upgrade. lol.
might rebuild mine again if im not happy after wednesday :P
I guess its designed to crush during an accident, so it will still serve most of its purpose there. However, the front tow hook also mount onto it- I wouldn't expect it would have the strength to put it out of a bog/ditch anymore. Not much of an issue really, its not like we treat them like a Landcrusier! Except maybe Craig...
Ben - Taste is personal, good on ya for making it your own. If you like it, thats all that counts!:thumbsup:
Thanks man...
I've got 610cc in there....still room to move if I wanted as the highest duty cycle in have seen so far is 67%....that was a run to the end of third gear....I HAD to overtake a couple of semi's! ;)
Thanks man...
And how fast were you going Craig?? lol
its surprisingly hard!
it disfigured in stephens accident but didnt twist or bend the rails. the entire car is dead straight. that bar took all the major damage.
I'd suggest plating the inside edges with some sheet alloy, then welding. That will give back a fair bit of strength.
It will also stop them filling up with small birds etc... :whistling:
Kudos mate, looks great!:thumbsup:
Spent a few hours cleaning the boat yesterday; quick wash, clay, swirl remove, polish, wax. Christ my right shoulder hurts :rofl:
Highlighted how badly my front bar needs to be fixed up too, lots of little chips at the front. The paint is silky smooth to touch now though.
looks great tho duncan. perhaps ask chipsaway (the company) for a touchup quote?
Cheers mate.
Yeah, I would if I didnt need more work done on the front bar - Ive got some cracks in the fiberglass on the passenger side near the headlights :( When I get that fixed up (and the dent above the drivers front wheel arch!) I'll get them to touch up/respray the front bar.
I know some of you are gonna be wanting shift kits installed in the upcoming weeks.
Well Im delaying my tune for about a fortnight - a month as I dont want to have slipping issues.
for the Vic Stagea owners, RVO Automatics in dandenong just quoted me $550.00 for an RE5RO5A(M35 box) Stage two Shift kit..... Installed! I had to ask him three times before he turned around and said "I own a C34 - I know what an M35 is" Lol
if anyone can tell me why I shouldnt take it there, I'de like to know as Im booked in next wednesday :P
Nice work Aaron! :)
No reason why you wouldn't take it there as I have not heard any negative things about RVO.
He knows the transmission.
He knows the car (!!!!)
The price is good.
I guess the only questions is workmanship, but someone has to be the guinea pig ;)
Ask him how much if I just send him the Valve Body....and what's the warranty.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
