Fitted bilsteins back in with Nismo springs, had rotors machined, fitted new front shaft and changed the steering pump to the new spec one! All in all feels great....but the f#%king vibration is still there under load when powering to the left! .... I'm lost :(
Could it be Atessa related?
Might be....tried bleeding it a couple of times now though.....my go and get it plugged into a consult to run the pump. Onto other new though...the power steering pump works well even though I have no adjustment because if the larger wheel....bit heavy on low revs but nothing unbearable.
drop the shaft from the xfer case to the front diff and see if the vibration disappears
Wont all the transfer fluid drain out?
We really need to find some method of running the attessa pump to assist bleeding, I will look through the wiring diags Prince Skyline lent me but I cant read Japanese...
Does it happen to be similar to bleeding attesa in a late model gtr?
Maybe but cannot find the fuse under the dash.....it's more than likely right in front of my face but I cannot confirm which wire we which!
And yes your right about the shaft Scott!
isnt it a plug in behind the right kick panel? i remember seeing it somewhere in the stagea manual.. gimme a tic and i will find it.
Here's some pics of everything I've done to the Stagea lately.
Sold the Garrett 2530 and replaced it with a Garrett 3076 :D
Went to see my brother for some stainless allen key bolts and washers to compliment the polishing under the hood.
This is how my engine bay looks now.
Also refitted the HKS pod filter and Greddy catch can. You can also see my radiator and fans setup. There is an oil cooler in there somewhere too :P
:thumbsup:
  • Like 1
would be great if you could....then if you could give me a pointer on how or a link to use it that would be great!blush.gif
Once you work out a fix, let me know! I have the same problem with the vibration under load (and cornering). :yucky:
:thumbsup:
looks killer mate, when does it get tuned??? who's tuning it for ya??
Im pretty sure everyone who has lowered their car has a similar vibration...
  • Nope 1
I FINALLY got on the dyno today.
exhaust is restrictive as, but none the less very happy with the result(for now)
229awkw with 702 NM of torque..
exhaust will be changed soon so we'll see how it is in a month.
ill put up a dyno sheet tomorrow at work :D
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
