Iain, so pretty much what your trying to tell me is that you bought a Bugatti, but you paid 45 gees for it. ermm.gif
nah, I like them actually.
Edited by PN-Mad
Reading the reliability survey don in the USA I am not so sure you are right about this.
VW rated 56th out of 60... :whistling:
So as in 4th from the bottom?
which means Audi > VW yeah?
Not sure what your point is? LOL...
Just read the JD powers survey....Audi A4 seems to trump Passat and Golf GTI in overall reliability? :/
Edited by ironpaw
i paid under 40k for my Octavia, drive away.
the only difference - besides looks - in most of the lineups over all the brands, is the panels.
most chassis are the same, engines, wiring, even down to steering wheels etc. my car is covered with VW and AUDI stickers on parts.
you guys bag them out, but come and look at it, its better than you think!
brake lines finally fixed. With big 324mm rotors and dogbones, with bilsteins & camber arms, the line fouled on full lock against the swaybar. Used a 90deg fitting at the R32 caliper so its all perfect now. Brakes feel as meaty as ever!
Will fit new qfm pads & shim kit after midyear exams I guess, to do away with the front rhs squeal.
End of year will do a hiboost tune & see what the forged motor can do :P
Lol, My sis had a Skoda Superb (the next car up the range in size) when she was out here for holidays last year, and it was very nicely finished. Had the 2L TDi motor; for a big car, it was quick!:thumbsup:
yeah the supurb is nice, but out of my price range, and IMO a little expensive for a less-well known car
Who cares how well known it is? Most people don't know what a Stagea is!
How is the VW anyway?
finally did some work on the poor neglected stag today.
Switch for the boost controller
New aerials for the tv (works good)
Speedo corrector for the nifty nismo dash
Didn't work out why the reverse lights aren't working....next time.
I installed a wastegate actuator with an external spring, Twas a right pain as had to remove most of my intake to get the job done, but by all accounts it will help get the most out of the stock turbo so a worthwhile exercise.
Thanks Scotty, I'll have my old one back to you in the post on Monday.
No problem Leon, glad its you fitting it. lol. You got a decent boost gauge? My old one read 3 psi low. >_<
Remember to block the stock bleeder or re-tune your controller if you have one, then wind it up slowly, checking the afr's if you can.
No problem Leon, glad its you fitting it. lol. You got a decent boost gauge? My old one read 3 psi low. pinch.gif
I've got 2 boost gauges & they read differently too. I've just been out working through the process of adjusting boost & fuel mixtures.
I started by allowing the wastegate to see all the boost & then slowly reduced the solenoid duty cycle (cuts off air going to the actuator) to add more boost. Got a bit greedy a few times & took too much out - hit boost cut :/
Had to add more fuel for the high boost map as well. It's not perfect yet, but felt it best not to tear up & down the nearby country lane all afternoon. The farmers don't mind me tuning now & then, but I've got to be considerate of their peace & quiet.
So far it's looking promising with more boost available where it was falling away before.
Did you use the Jaycar one? Pic of cluster please!
yep, the jaycar kit, works perfectly. Just tapped the speedo wire at the dash and hid the box up behind the hazard light switch. It's been in there a while bu I had to adjust it because I've changed rim/tyre size recently.
Nismo dash is the main reason I had to fix the speedo. A big digital speedo is just annoying when it's wrong!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
