Straight swap? Nice butt and rib hugging?
pretty much straight swap. Hugs the body perfect. Sits alot lower then stock seats but works for me as im 6ft. I had to use my oem seat belt retainers as the 350z ones wouldnt secure the seat belt. Driverside was 100% plug and play but the passenger side for some reason one of the plugs were removed and the inside front bolt hole was out so needed some massaging.
Fitted rear white line sway bar with whiteline bushes and stock links. Find it very squeeky. Id say it may be the links causing it. I greased them up again and it went away for a while but is now back really bad. Any ideas?
Piss the links off & get a new set if they're creaking; they should be silent.
If it's the "D" bushes, replace them with either Whiteline or Nolathane PTFE lined versions; these require no lubrication for their lifetime.
They are whiteline bushes thats where i was shocked at the noise. Ill replace the links with whiteline adjustables and see if the massive creaking stops. You would have possibly heard it the other day when i dropped around
I did mate, if they were the PTFE impregnated ones; they wouldn't be doing that though.
Let me know if you want me to get you a set of links; I still get good pricing...
Whilst my M35 is on the hoist might as well replace things that need it...
Therefore upon closer inspection the radiator will be replaced... won't have to worry about the auto transcooler getting in the way with the new one :P
Over the weekend i installed the Fujitsubo Legalis R Exhaust. Huge difference in comparison as you can see. The muffler that was on the car was bi modal, controlled via a switch in the dash, not sure if its a factory option but maybe someone here would know.
I havent had a chance to hear the new exhaust as i did the rocker cover gasket at the same time and after doing that the Stag had developed a missfire, Code P1320 - Ignition Signal. Need to fix this before i can hear it 100%
12074895_10153046249637676_3059617772022
12122691_10153046249672676_2256926647232
12144951_10153046249712676_5860858177737
You can see the adjustable valve, the motor is in the back of the car near the standard TV receiver.
12116008_10153046249732676_6834594809952
12106769_10153046249762676_4524905020275
12141774_10153046249792676_6757258097205
  • Like 2
Is the old exhaust you pulled off branded? Or do they come factory option that way? Guess that's the switch under the dash then right?
Looks like the Skyline coupe mid section, repacing the usual massive mid box, and the Nismo accessory sound control exhaust... I had one sitting in my shed, as I never quite got around to installing the motor and wiring before i sold the car..
But I did have the coupe mid section.. Well worth the $120 and 30 minutes fitting...
Had the airbag light always on and the A?T check light came on a few times too.
Did the sequence with the key to get rid of airbag light, and added trans oil (matic J).
No more lights showing up :)
Just have to look up that rear right noise next and it will be all good (will make sure I check the handbrake cable).
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
