On 21/01/2018 at 7:11 PM, KiwiRS4T said:
Looking good! So what offsets work on the 8 in rims? Different front and rear?
The width is actually 8.5", and the offset is 45. they sit nicely just a smidge behind the guards. The 235/30 tyres are a bit too slim for my liking, so probably will swap to 235/35 down the track.
Connected my phone to the factory Bluetooth.  Phone controls on the wheel work too. Noticed the voice recognition understands English but you need to know the names of the menus.......  Anyone got more experience?
  • 1 month later...
Installed MCA Street Performance Series coilovers, Driftworks front upper camber arms (approx. -6 deg in front and -5 deg in rear), Garson Deep Racing Ryugi wheels on the front in 18x11 -22 (have to re-lip the rears from 18x12.5 -22 to the same specs as the front before I can run them), painted brake callipers and installed a sub and amp. Nothing too major but its a start on my static VIP-inspired build.
Edited by Caleb_M35
  • Like 2
Brake upgrade on the front completed, they're only little 8pots, 4pots to go on the rears once bracketry is sorted for diameter and offset.
And finally able to get new rims fitted now that brakes are done and allow clearances
  • Like 4
On 4/3/2018 at 5:19 AM, TukeH said:
 Finaly I got fmic installed. I did not notice the difference
Later have to buy aluminium pipes to.
Also I bought bc racing shock cover bags
You need to up the boost to 10 psi
  • Like 1
Will look much like this just tidied up. I have to clean up the clear lenses to go over the front to seal it. The light bar is custom from my company I had. They are about 4 times brighter than the stock high beam. The strip across the top is daytime running light and indicator in one. The halos are park lights so will come on with the auto headlights. The flashing lights in the sides are just for when the cars on show.
It is very hard to recreate the mounting points for the stock HID as I have cut 2 of the 3 off to fit the light bar
Any link to where to get that day time running light? Looks like its made out of silicon?
Aliexpress
http://s.aliexpress.com/vmYN7BFJ?fromSns=Copy
Had to cut holes into the panel to wrought the light. It's too long and to attach you need to buy double sided tape and I drilled holes through to use some wire to make sure it doesn't come off.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
