On 9/2/2019 at 3:00 PM, TMLP said:
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Head should be back from the machine shop tho week. Gone with big cams & valves, springs a shimless setup  plus  rear head drain & NITTO oil pump. Getting close.
  • Like 1
Pulled out both hubs to replace bearings only to find I need ball joints, cv boots & tie rod ends as well....
You would think Pedders would have picked up on this when they did their inspection and told me they crushed the ball joint when they put it in.
Never going there again.
Started extricating the stagea from the garage today.
planning to get it back on the road. just need to fit the cupboard full of parts i have for it.
5 hours ago, TukeH said:
Just one thing what I have been done 1month ago.
Went cardealer in southern Finland and chance my Stagea to this
Cool - more info and pics please!
Honda Odyssey absolute 2.4 k24a2 engine.
Only 200hp and FWR it is slow otherwise its much better driving than stagea and its more eco friendly 6-7l/100km
Future plans. air suspension and new rims
  • 1 month later...
Ok it’s gong in here are some pics as promised.
  • Thanks 1
  • 3 weeks later...
So on the Maatouks racing FaceBook page..
www.facebook.com/maatouksracing/
Shaun’s stagea came in for a MR 700 package packing a RB30/26, 6 boost manifold, garret gtx35/84rs, Turbosmart 50mm wastegate, ID2000cc injectors,custom cooler pipes and catch can all controlled through a Haltech plug and play ecu with all sensors and wideband for engine protection and peace of mind. Making just under 400kw @ 16psi at only 6000rpm on a running in tune.
6 hours ago, Duncan said:
great outcome from the engine these cars should have left the factory with :)
let us know how it goes once you lean on it a bit.
1000 k's on low boost the retune on E85 then I'll give it a bit & let you know how much I scared myself
40 minutes ago, KiwiRS4T said:
My C34 was pretty quick with 320awkw - yours should really shift with 388 and should be fun on the track with over 400!
I hope so, its going to be interesting to see how quick it is being so heavy after run in & the E85 & boost turned up ;)
On 11/30/2019 at 2:04 PM, RBW49N said:
Fitted this the other day so comfortable
What rails are you running with these?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
