On 9/2/2019 at 3:00 PM, TMLP said:
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Head should be back from the machine shop tho week. Gone with big cams & valves, springs a shimless setup  plus  rear head drain & NITTO oil pump. Getting close.
  • Like 1
Pulled out both hubs to replace bearings only to find I need ball joints, cv boots & tie rod ends as well....
You would think Pedders would have picked up on this when they did their inspection and told me they crushed the ball joint when they put it in.
Never going there again.
Started extricating the stagea from the garage today.
planning to get it back on the road. just need to fit the cupboard full of parts i have for it.
5 hours ago, TukeH said:
Just one thing what I have been done 1month ago.
Went cardealer in southern Finland and chance my Stagea to this
Cool - more info and pics please!
Honda Odyssey absolute 2.4 k24a2 engine.
Only 200hp and FWR it is slow otherwise its much better driving than stagea and its more eco friendly 6-7l/100km
Future plans. air suspension and new rims
  • 1 month later...
Ok it’s gong in here are some pics as promised.
  • Thanks 1
  • 3 weeks later...
So on the Maatouks racing FaceBook page..
www.facebook.com/maatouksracing/
Shaun’s stagea came in for a MR 700 package packing a RB30/26, 6 boost manifold, garret gtx35/84rs, Turbosmart 50mm wastegate, ID2000cc injectors,custom cooler pipes and catch can all controlled through a Haltech plug and play ecu with all sensors and wideband for engine protection and peace of mind. Making just under 400kw @ 16psi at only 6000rpm on a running in tune.
6 hours ago, Duncan said:
great outcome from the engine these cars should have left the factory with :)
let us know how it goes once you lean on it a bit.
1000 k's on low boost the retune on E85 then I'll give it a bit & let you know how much I scared myself
40 minutes ago, KiwiRS4T said:
My C34 was pretty quick with 320awkw - yours should really shift with 388 and should be fun on the track with over 400!
I hope so, its going to be interesting to see how quick it is being so heavy after run in & the E85 & boost turned up ;)
On 11/30/2019 at 2:04 PM, RBW49N said:
Fitted this the other day so comfortable
What rails are you running with these?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
