Priorities are probably power steering cooler, wheel alignment, and finishing the brakes off.
Once again, I'll throw my support behind the power steering cooler. I proudly took delivery of a $980 power steering pump today to replace the one I flogged out after 6 laps of Mallala. The half lap I did while the fluid was boiling allowed the vanes to contact the housing and wore the bottom out of it. Fluid has been madly circulating around in the pump (instead of going to the rack) ever since.
And it's a bitch to get off.
The standard brakes weren't much better though, even with the HPX pads. Hopefully your DBAs will hold up a bit better. Although I didn't change my fluid...
Sorry to hear! Maybe I'll go the bigger power steering cooler just in case then...
DBA are pretty confident in the brakes, and have given me some guidelines. Guess it'll be a pretty good test for them, wouldn't think they'd usually get tested in 1.8 tonnes of fun.
Who is making your suction pipe Ryan? AM I'm guessing?
Yup, AM. Andrew is making my suction pipe while I get cracking on his web site.
haha, favours. Just remind him to put the AFM on a straight section.
On topic - I've done nothing to my Stagea today. I can't drive it. I'm starting to get withdrawal from not having it in my garage! blush.gif
I cant remember how many failed intake styles I tried before settling on my current design. I hope he gets it right. Do you have a wideband in yet?
Should be going in at the same time. He's made plenty of others for RBs - is there that much difference in the air intake?
And increase your fuel pump pressure... my car was massively lean without the fuel pump.
Have you seen the space you have to work in?
Yeah I have a new Deatschwerks pump to go in that should take care of that. Just getting the wiring sorted.
There is no space, well aware! Andrew seems to think it's no problem. If it is a problem, it'll be his problem! I'm sure it'll be fine.
Mine isn't & it works perfectly well (after some special tweaking). First try too :nyaanyaa: .
Maybe you should send me the secret Wyle E Coyote blueprints then? :nyaanyaa:
Hahha. I wish I took more measurements/details so I could share. But one of the reasons I'm so pleased with the outcome is my ~25% air bypass of the AFM which stops me hitting the voltage plateau.
The Wyle Coyote blueprint that I bought of the 'net just had a fan & a sail so I got ripped off.
Today I got my nismo suspension from troy and had a spare 4 hrs so thought id give it a go installing them. First I had to buy a set of spring compressers so I could put the front struts together. After a little of stuffing around come up a treat. Then I set to work starting on the passenger side where I ran into some trouble with a seased on the bottom of the suspension arm so I had to cut/grind the nut off. So had to go to bolt king to buy another nut so got nyloc nuts. After 3.5 hrs I got the passenger side done. What a nightmare that was. Then I started the driverside and that took all of 25 mins. so I now have the fronts in. hoping to have the rears in for goldcoast cruise on sunday. I also measured all 4 corners before and after installation. Fronts were 710 driverside and 715 passenger. After I put the fronts in they were the same measurements but after I took car for a spin they settled to driverside 690 and passenger 695. Still after all that went on this arvo still happy with my new nismo suspension.
Finally got around to cleaning the blue stag... Ten weeks after baby was born!
Gotta say another couple of dints/ scratches that were'nt there before thanks to the wife for trying to park next to nice cars.... Told her the ones with the bmw's and Audi's plus kids care less than the commonwhore owners!!
New front tyres from Etyreshop in Brisbane (Geebung).
235/40/18's for $125 each fitted & balanced :)
You really got your moneys worth out of the old ones.
It wasn't that bad till I ran over something on the motorway & a few days later I heard what sounded like a line of tread flying off... I pulled up & saw what you see in the pic. You could actually put your fingers between the tread & case.. very scary. Drove home @ 40 kph & next day bought the new ones :)
AM Performance finished my new intake pipe. Will post pics later. I finally have everything I need to do the cruise control so thats my plan for today, depriving Leon of any and all comedy material he may have been preparing.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
