You only need to drop the diff, not the whole subframe. Better get on NS and have a look, what do us guys know of race cars such as yours...
Is there enough room on the skylines to mod incar Scotty? I have never bothered to look...
I doubt it, mine is r200 also I think, the breather is in a prick of a spot. If it has a hose on it already you might be able to extend it...
The M35's had hoses on some, and little breather caps on others. Not sure why the differences.
Bugger!
It does have the push on hose type setup... Might be able to just disconnect the old one and leave the hose there and run a new line upwards somewhere... Ill have a look on the weekend!
Not that fussed tbh.
It's lived doing track days like this for a long time... Doubt I'll break it.
What does the r200 have for a breather?
Anyway, next up for me is a bigger bmc.
I dont want oil near my brakes or tyres... I have enough trouble all on my own without that :P
Ah, piece of piss then, just make a longer hose, and end it in one of those bottles you seem to use ...
:P
Lol that was Adams last minute modification :P New setup is in planning at this stage... Will hopefully involve Hypertune etc
Pipe the breather into the exhaust! That'll keep the oil off your tyres and brakes. :woot:
Most of the exhaust gas seems to flow out the slight leak that some call a screamer :laugh:
Matty I finally did my power steering cooler after one year of talking about it haha..
I used red gates hose because it's half the price of black gates hose and the core is from a R33 auto transmission cooler
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
