and just to touch on the said sump builder, he races a 32 gtst that runs anywhere between 450-600kw's and is one well sorted rig. wet sump, no oil drama's. oh and it revs well beyond 9
also, love this build to death, huge inspiration for my own build. keep up the good work
Hey Russman
Have you sorted a sump? regardless what you buy you will need gates not just baffles and extra capacity. My tuner builds them. modified pick-up gated and winged. they arent cheap but non of them will be. i think $1200 bolt up no mods.
you also have an rb25 gearbox dont you russ? thats another 15 odd kg over a 20 box.
im guessing you have an unstripped loom? do you have factory intrusion bars in the doors? its been proven time and time again that stripping door frames has little advantage. viva garage used to do very cheap fiberglass doors that cost around 400-500$ most of the weight in standard doors is in the hinge and latch areas. not easy to remove them.
if you take a look under the back of the car and the subframe there is a lot of small weight to be gained. We were able to get bens targa car to 1230 in rally trim without any expensive light weight parts.
if you want to cut weight you have to look at everything as weight. and work out if you need it or not and how you can make it lighter. every little bit counts. and remember removing weight is free power and free brakes.
Good luck for WTA
Yeah Racepace are making me a sump and modified pickup. It is gated.
Getting fitted today.
Yeah 25 box.
Loom is yet to be stripped out...
Door intrusions will be removed soon. Even with fibreglass doors you still need to retain the latch and hinge so I'll stick with my steel doors till I have some money to burn.
Think the next big thing after I strip doors and fit lexan will be the loom. cbf at this stage. If I have time before WTA I'll give it a go.
thanks for the input.
Re wiring from scratch is where you'll make decent gains. I just striped mine down to the minimum up the the fuse box and I saved about 3kg. Nothing to write home about but better than a kick up the ass. Intrusion bars are 2.5kg, each plus I took some door frame out to help getting the bars out, whick took it up to 3kgs. Lexan and lightweight mirrors netted me just over 6kg saved per door.
With an R32 it's 100x easier to get some series 1 doors than drill the bars out. I've got a feeling they are made out of thinner steel too, as there is 10kg a door difference between s1 and s2
If i remember Russ, I'll ask Collins how much wiring he got out of that fire engine gts-t mentioned earlier.
I saw half way pics and a fair bit of crap had come out of it, be interesting to know just how much the end result of a strip/re-wire was
Unfortunately the new custom sump was modelled on an R33 and it didn't clear the swaybar enough when we put it in last week.
Because of this we missed out at PI on the weekend. I had brand new rubber on the thing and was ready to go but no such luck...
Upside to that is I got more done on the splitter. Only a little bit to go and it'll be done.
Thanks to Matt and the guys at SX Developments for the advice and sharing their support frame design.
Started with an MDF sheet
Also fitted up a power steering cooler to get past some heavy steering after a few laps.
Russ, interested in how you mounted the front tow hook... Can't really see from the pictures what it's bolted to?
It's bolted to the chassis further back. Had to weld an extension so it would protrude though. They never sell them long enough.
With the splitter we have ideas on what we want to do long term but time doesn't permit for this year. Perhaps next year.
Carbon fibre and much fancier diffusers.
Are you going to leave the splitter as mdf or are you going to make a mold of it?
I can't remember reading back about it but did you change your front spring rates when you changed to the 25? Do you mind sharing what you are running?
Looking good
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
