Need your opinion guys. Looking at installing a Walkinshaw bonnet vent on the SS-V but not entirely convinced yet.
I love the look of it but not sure how it'd look on my car. Main reason for getting the vent is I've noticed the amount of heat trapped under the bonnet is ridiculous, and apparently the ECU in the VE's retard timing like a mother when it gets overly hot.
Pic of my SS-V halfway down the page here:
http://www.skylinesaustralia.com/forums/topic/329280-victorian-post-your-ride-thread/page__st__1860
Pic of the Walkinshaw scoop I'm referring to here:
http://www.caradvice.com.au/wp-content/uploads/2011/04/FR4E7195-625x416.jpg
http://www.hp-f.com.au/wp-content/uploads/2011/07/powerhood_01_full.jpg
http://www.stationwagonforums.com/forums/gallery/files/4/2/7/1/26s.jpg
Yay or nay? Be a fag without a vent or be a fag with a vent?
http://www.skylinesa.../page__st__1860
http://www.caradvice...195-625x416.jpg
http://www.hp-f.com....ood_01_full.jpg
http://www.stationwa...4/2/7/1/26s.jpg
Nein.
And you should chuck a Vauxhall badge for lols.
fast and furious 6 hero car....
BenSopra kits look shit!
I was gonna say, do these bonnet bulges do anything or they just for looks.
Looks like they just stuck it on top of the bonnet.
Or are they whole replacement bonnets with the bulge and vents?
Hahahaha thanks for the input guys. I do like them but again, unconvinced that it'll actually look good. The vent is stuck on but does require the bonnet to be cut if it was to actually work (what I was wanting to do). Wouldn't install it if it wasn't going to function as a vent for heat extraction.
Anywhoo, thanks heaps for the thoughts guys, looks like I might skip the bonnet as it doesn't appear to be too many fans :)
NOT ROADWORTHY! YOU CUT YOUR BONNET!
oh its a commodore. youll be good. lawl!
Do it
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
