yeah... although there is literally no passenger seat left... the pole went right through and is where the drives seat should be.
I can see him walking unfortunately :/
Coupes are more expensive yes. I completely forgot about getting some prices for you. Sorry man. Will check in the morning and let you know
I thought the same sedans look heaps better
Sweet no real rush not like I'll be buying next week anyway but send em over whenever you get a chance so I know if I'm dreaming or not...
Sedan it is.
The only reason why I say not with instructor is because of price. They usually charge 1 hour lesson beforehand + vicroads, so $220 all up
It's pricey but so are retests...I considered it insurance at the time. My instructor and the tester were old mates and the instructor was telling me he hoped we would get him haha.
So yeah, in short, I shouldn't be on the road.
F6 310 or FQ 340
e8MR or e9
with almost no money spent is quicker AND more responsive than FQ
and F6 depends on how much you want to mod
my 7, the money has already been spent. its clean and rust free, aaron also checked it out when it was forsale in vic.
http://www.skylinesaustralia.com/forums/topic/436461-2001-mitsubishi-evolution-7-249kw-on-98/
Abz, I don't think they'd fail you straight away but depending on the square you get maybe they'll be a bit prejudiced / tighter for it...
I just used my mates impreza (just an rs) for the test lol
Cheers for the advice brahs!! :) Yeah got done for driving manual on auto licence so going for the test this friday. RACV peeps all on holiday so imma try someone else tomorrow but other than that i'll just take my mates accord euro, no point going through all the hastle in the skyline plus scraping at vicroads lol.
remember to double clutch and not granny shift
but he no buy, so not good enough?
Who was the bloke that tried to sell me a set of tri spokes that isn't Niroj or Mike a while back?
It was white late model tris in 17s from memory?
I want white tris now. Halp?
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
