Unrelated;
After hail damage, front bar scrapes, bonnet chips, mismatching panel colours from previous repairs, aging paint and now a rear ender...I may be respraying the R33.
Colour suggestions?
You have already decided on the colour :/
I'm also deterred by the cost of hiring a full time security guard
Don't be daft Adam, that's just added expense for R34 GTR owners.
Can be easily avoided by buying a R33 ;)
orange.
then get one of those spray jobs on the bonnet that look like it was a failed tattoo idea. good resale value on gumtree.
but serious, if wanting to be original, some subtle shade of orange
orange.
Why don't you paint your Pulsar Orange with white stripe in the middle?
orange.
In before Aaron.
1. Parent of the year
https://www.facebook.com/photo.php?v=452393244798972
2. I'm not even going to reply to the color suggestion request, since it won't be one of our suggestions anyway.
3. E85 E85 E85, how did I know that would summon the E85 god himself?
4. Alvin just got defected, but... I thought his car was compreetrie stock?
Cheers for the info re: gtst and gtr, hence my question as to how different they really are when fully set up
Which seems hard. For what its worth I wenT WOT from 0kmh with 375rwkw and had traction in first which was rather suprising. Howvever around a corner is considerably less likely.
Scotty would know how much of a stickler I am for the stealth look. If someone was just looking to buy a rb28 neo I'd sell them mine.
As for r33 colours, go get House of Kolor's Galaxy Grey. Someone did a drag r33 with this colour and it is fantastic. I asked about it for my r34 before the convo subject changed to 'prepare for write off'
Unrelated;
Colour suggestions?
Same colour. Unless you are doing bay, door jams etc, in which case MNP
IMHO darker colours suit the 33
Hey man that hurts :(
You can do that with a GTS-T though, to much the same degree...injectors are my only give away cause I cbf spraying them the standard colour.
Return flow IC is legal as long as you don't have a pod.
When I drove a GTR I wasn't impressed. Maybe it had been talked up or I don't hit the corners enough to justify having AWD, but having come from a well sorted GTS-T, I wouldn't pay the extra money.
I failed my full EPA because injectors were the wrong colour. Even though I passed the emission test.
I must say the colour choices you guys suggesting are bland as f**k..
gunmetal grey, bayside blue, mnp... Come on guys pick up a colour chart that isnt from the 90s nissan catalogue...there is 11ty billion more exciting colours to choose from...
a deep dark cola coloured red would look amazing...And the things you can do with silver to increase its impact 100 fold... Look at new cars for inspiration, mazda for one have heaps of cool new colours..
Think outside the box peoples..
that means that moorabbin guy was being a flamin mongrel to you.
i spotted his car at photoshoot the other night, all i could see was a piece of the front rim , i gone to Mick, is that Gregs car..lol....Its pretty messy...It just destined not to be on the road that thing.. You tried Greg, you tried really hard and you attempts all though futile are admirable..
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
