What do 33gtst fuel tanks normally go for? I've got one on the floor of my garage taking up space...
They worth a pineapple on drift sales or not?
Its got maybe 5L of 18month old 98 in it, so that'd raise its value in the eyes of some of the drift kids
Not sure its worth someone knowing my address and location of car :P
no ethanol, no deal.
Bought some floodlights inside the garage, never have night lighting issues again...
Good size, nice and solid waterproof metal casings...
Earth wire, CE Logo... goood goood...
Fúck you Chinese Safety, super kwality number 1!!!
There are screws in the vicinity which they could be attached to in order to make it safe against electrocution, considering the complexity of the product... it would take an additional 3 seconds to make (on a 5+ minute assembly time). Increasing the quality and safety of the product substantially... which could raise the number of sales compared to other dodgy competitors.
My company does our equipment production in a Shenzhen factory now, we thought it would be a set it up, train them then forget it process... Nope, we've now got one of our staff permanently in china to oversee the operation because standards drop within a week of him leaving the factory floor.
I dun get it
Why would they increase the safety, you already bought the product and your negative review won't stop others either
People buy this stuff cause bargain bin China
It's like the split dump pipes on eBay...absolute f**king garbage and will actually f**k your turbo up, bad reviews everywhere, but because $99 and shiny people still buy
  • Like 1
Yeah ebay, from an Australian seller... Will make them electrically safe and then test them for heat output over extended periods of time before installing them...
I got 5 x 30W ones... If they were halogen ones I'd need to put on sunscreen, these are LED so I'll just need sunglasses every time I go into the garage.
ouch at the earth thing.
i recently bought one of these:http://www.ebay.com.au/itm/310876695793?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
aldi were selling them too. pretty handy.
that looks quite good, handy for track days too, happy with it?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
