This actually makes sense to me given the shock I experienced at discovering Leesh had never had a slurpee...I acted quickly to fix this
And all the perthfags taking home Krispy Kremes from the airport
Haha and we might be getting our first 24hr Kmart too!
so we had to do overtime last night and one of my workers magically had a head ache and had to go home at 4 yesterday.
so we pushed on and got the job done, scheduled a 7am start today, dude calls me at 7 and says he has a lawyer appointment at 7:30am.
okay then. finally, bust him chillin and doing nothing.
what the f**k
Call him and ask him what's going on and why he couldn't make it into work... Mention that you need reliable workers to get the job done.
Also, track everything... times/dates/conversations in case he tries for unfair dismissal after you boot his arse because he's crap
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
