i semi-dated chinese once...
something about the forceful parents, dedicating life to studies, disapproving grandparents who lived at home, who also didnt trust anyone with a beard and who also didnt understand why i wasnt studying because my profession isnt translated well in chinese (pick a language)... made it hard for a relationship.
and she was pretty sheltered.
aka didnt want sex. just lots of public affection. a real winner.
  • Like 1
the other kind i know are at the other end of the spectrum...
working at bars, failing studies, lying to parents about said studies + life in general, hair budget exceeding food budget and constantly posting selfies and/or hand gestures.
10403820_542754362496544_166406853503154
a real winner.
and then there are the ones you buy.
who need constant prada and gucci handbags. brand new cars every 6 months etc etc.
and in reality are sleeping with me more than they are you, because well, your rich, but im better looking.
haha
story may or may not be true.*
*cairns has a high population of token asian brides.
*i used to live in cairns.
Possibly the most accurate generalisation I've ever read
a real winner.
Also quite accurate
Chinese girls have always seemed boring as shit to me, too reserved. Those ones you spoke about in your first racist post, at least. It seems like if you were to pursue one they would eventually open up to you and reveal more boring shit under each layer of personality, until you got to Pandora's box, where to your surprise you would find...a plethora of boring shit.
Me: ever done anything adventurous in your life?
Chinese girl: I once played a D minor piano concerto in D major
  • Like 3
I'm sure there's plenty of different shades of boring shit to amazingly out there.
People just take note of the super blah beige personality and the extreme opposite of that (probably due to rebelling against option 1) of the chick with pink hair going all out stereotype.
There's got to be in betweens, but so normal that they're just you know... normal people...
LOL! @ trying to date and figure out a Chinese girl.
I think people would make the mistake of trying to work out things that aren't there.
The fobs I know are pretty straightforward girls, simple priorities that are well sorted and predictable. Seems to me if you want someone that you don't have to figure out, then head in that direction.
Stark generalisations are fun.
Yeah generalisations are fun, cause most of the time it's stereo typically true.
I took an Asian girl out to dinner, under the condition I bring my parents (because she wanted to meet them) and she can bring her friend.
Most awkward dinner ever.
She has lived in AUS for 10 years but still retains the FOB values.
  • Like 1
haha I would rather have a table for one than bring parents along.
there are plenty of people between the spectrums and even the polars can be really cool people. just two noteworthy people I thought fit the stereotype in a depressing way.
birds, what you speak of about the searching for something if ladies open up (their minds/hearts). it certainly drags me along even though until now I hadn't really thought about the 95% of the times the knowledge gained was nowhere near the worth the effort it took to get it.
in gaming terms, it's like an MMO. much heartache, grinding and adult diapers for a very small return. just settle with what you can get cause it's not worth the effort and is a much better investment?
  • Like 2
PS I'm writing this while sitting in a foyer at southland and my outlook on life is changing as more and more track suit pants walk past.
need to get out of here. (least it's not chadstone)
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
