ok so officially cracked it with news.com.au, I've known it was bad for years but it was easy, however when the 2 main articles for today are:
article 1
EASY KEYSY: How to buy a home with one simple, dirty word
article 2.
‘We just saved $3000 in one day’
THEY saved thousands in hours, and all they needed was one simple secret. Now these Aussies share their shopping tips to help you keep your cash.
So suggestions for Good AU based news sites?
  • Like 1
Track Skyline, boost power a little, drop insurance down loads
Daily Evo, leave stock'ish
Less stress living next to knox, less "not being able to get to work on monday" if something goes wrong on a track day, 4 doors more mohsens
article 1
article 2.
Yeah saw that today. So lame. One talked about saving and the other talked about haggling when buying anything.
Sounds like those stories they run on A Current Affair about how you could save "Hundreds" on cleaning products by going natural... and the end result is instead of buying "Toxic chemicals which could be hurting your family" you make your own at home our of shit like Bi-Carb Soda and Lemon juice... end up spending 2 hours doing 20 minutes of cleaning each week because of your sub-par cleaning products, all to save $200 over a full year.
  • Like 1
Pretty much the story behind every DIY thing that people learn to only do it once...spend twice the time learning something that could be bought with wages from half the time working one's normal occupation!
The time people waste on shit, could get a second job and earn heaps more lol
Yep, but with car or construction based DIY I still find it worthwhile for the satisfaction of doing it yourself.
I don't get that with making lemonjuice in a spray bottle to spritz on my shower tiles...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
