Did lol.... at:
Hamish getting mad bro
Realising a 2.2L is bigger than a 2.0L and there's near 3 times to power output from the little baby evo compared to the 5S-FE
The commodore because it looks like a decent burnout car and not a street skidder's first time at an event...
Hipster Lumberjacks complaining about the lack of nuttiness in their $9 mocha soy latte
Yeah, I've been on many a different Dyno...
Chequered Tuning
Chequered Tuning
Chasers
Chequered Tuning
RTR
RTR
Racepace
Not wanting to get involved in this jerk fest... but yes... one did read quite a bit higher than the rest. But at the same time, different tuners work with very different styles of tuning...
But... car was pinging on trents dyno and I NEEDED it for a DECA on the weekend so we pulled it way back for a "safe tune" of 230rwkw... a few weeks later (no mod changes) it pulled 212rwkw on RTR (Simple retune and it was back up to a safe 242 (which I'm estimating 260 on trents)
The only real reason I don't go back to Trents is because its too hard to get a hold of them and get a tune within a week of when you need it. Too hard to plan mod installations etc if you're not even sure if you'll be able to book in some dyno time before a track day.
  • Like 1
Spied a black 32 gtst on Center Dandenong Road with SAU Stickers this morning near Moorabin Airport as I was getting coffee on my way to work, Pat?
Surely its the only one left...
Haha unfortunately not. Just dropped off car at traction tyres for some much needed lows.
In before Xmas defect.
There is a tuner in SA that uses a hub dyno and massively over inflates his figures which has been the source of much controversy over the years, however this is due to the tuner and the correction method he chooses to run.
Leigh and Birds just run with it in VWL purely as a jimmy rustling exercise.
Oh I love rustling jimmies left right and centre, but I legitimately believe there's a significant difference between Trent's power figures and roller dynos. Have seen too many of his customer cars produce different results elsewhere at several different places, and no one in the country seems to be able to replicate mr HG's turbo results, except those who get their cars tuned at Trent's. It doesn't say anything about the tuner, unless they are in denial of the power reading difference.
The only reason I get rustled over the differential is because people masturbate to a 350kw run, talking about how responsive it is for so much power, when the thing would make 300 everywhere else. That and these people whinge when they go to other dyno days and are down 50kw, saying it's a shit dyno that must read low cause they lost all their power. Case in point: our SAU dyno day at RE customs 4 years ago.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
