I know of a surveyor who went to wa straight of out uni. Sitting on around $80k. To her and her peers it's solid dough, to me it's 3 years wasted on top of the 4-5 years total of uni-masters. But at least you have a life at uni. Who wants a house in WA anyway?
So my work car now is a corolla, 2010 or something auto with a whopping bb 337,000kms on ...
And I must give it credit..it gets whored out and cops a beating, smashed around bumpy gravel tracks in the dark and its still solid....and it goes reasonably well too...much better than that manual Hyundai gets I had that was also 1.6lt but always felt like it needed more power
Downpoints...cupholder is broken, tho still holds a takeaway latté...needs new shocks
85,000km/year... dayam... I'm always more impressed when small cars last a long time, instead of the usual 400,000+ falcon
So it holds a Latte for a while... and then throws it at you with disgust whenever you hit a bump.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
