Actually I transplanted the engine, throttle cable, struts, springs, hubs, brakes, lca's, gearbox, driveshaft, axel, diff, exhaust, fuel system, seat, quater panels and bumpers from other cars.
holy shit mutherf**ker yoda and shit
http://my105.com/ListingDetails/tabid/65/p/1/k/vq/id/8893/Default.aspx
who wants to help me pick it up from QLD?
I really want to help you but I can't be bothered
i wonder why the dude did such a conversion... i wonder what ECU. i wonder why he/she would go for a torquey motor in a kit car. why didnt they go non-turbo model? i wonder why they were happy with 250hp.
i would solve all of those questions.
inb4 spelling mistake and meant VG30DET
I know of a surveyor who went to wa straight of out uni. Sitting on around $80k. To her and her peers it's solid dough, to me it's 3 years wasted on top of the 4-5 years total of uni-masters. But at least you have a life at uni. Who wants a house in WA anyway?
Me
  • Like 1
85,000km/year... dayam... I'm always more impressed when small cars last a long time, instead of the usual 400,000+ falcon
So it holds a Latte for a while... and then throws it at you with disgust whenever you hit a bump.
Lol, not yet...
I think the way it is broken it actually holds the cup better Tha the passenger side that isn't broken...the cup sort of molds into it...
Best bit us, twice a night I get to bash it around some scrubby paddocks and a disused airstrip....for that 10 minutes or less....I'm Colin Mcrae..
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
