How frowned upon is taking a few sickies in notice period? lol
Keeping in mind old and new workplace are somewhat affiliated.
if you going to, be sure to back it up with a med cert cause it sure looks planned/dodgy...
Never good to burn bridges when moving jobs.
I'd rather get stabbed in my sleep than stabbed in the real world
Dream people can't really hurt you
That's what people thought till Freddy Krueger killed them in their dreams
Frowned upon, if their dicks just do jack shit at work lol
Is the sick day going to be on Monday? When apparently doctors offices are expecting a 1000% increase in visitors coming in for doctors certificates because the government has robbed them of a public holiday?
Compulsory medical certificates for 'sick leave' is the biggest waste of time. Probably clogs up 50% of the doctors office
Should just take it whenever you want, i mean if you take excess its going to unpaid/annual leave anyway
Yeah I think if we take a Monday or Friday or 2 in a row we need a cert.
I've had to fill out a stat dec TWICE because apparently they didn't believe I was sick. Shows how good this place is.
Lol what a waste of time
Because an employee is suddenly going to fill it out and say hang on i wasn't sick you got me. And if you have to get it certified, the other person is really going to know that you were sick on that day....
Get tune, million of comical errors happen.
Then lucky, Osaka imports open, and have the part I need that I spent many hours yesterday trying to get around.
Ace!
Drive there, obtain parts, two infact.
Correct issue with MAP sensor, so car actually running on flex fuel.
So good!
Test traction control, as it's wet outside. Working so well. So effective.
Listening to new album from favourite band, rocking out hard. Life is good. Great start to the day!
Then suddenly, kids run out infront of car. 1m (or what seemed like it) away.
Panic-brake, pull wheel in direction of "not someone's f**king kids", rear end loses it, end up mounting the kerb and parking on the nature strip in a very uncontrolled fashion.
Get out, yell at kids until they're crying because f**k SAKE.
not even my wheel
ffs
Totally because Greg.
Probably a better driver may have managed to countersteer and avoid the kerb, but man, panic braking means very little went through my head.
Still better than putting someone else' head through my front bar.
+1 funnies because its a borrowed rim, which means mine is fine...
I think it's repairable. Just looks like a lot of gutter rash. I do mean a *lot*. It isn't buckled, so I mean hey that's good.. I guess..
Guess whos' booking an alignment, though!
Any pro tips re: Wheel fixers? I asked Alvin as he got my wheels I sold to him repaired and fixed and repainted but no reply because reasons.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
