I just got a cheap second-hand Logitech GT. Not as nice as a G27 but can't complain for $60.
If you and Michael compete next week, should be a pretty full grid. Can keep me company at the back of the pack :P
Best thing I did was focus on setup and tweaking FOV to suit my sitting distance from the screen. Really helped me judge braking distances
Leroy is right about setup. Brake setup is uber important when its a fixed setup race too ;)
Playing a little bit with FOV am i right in assuming for a single 70" about 1.5meters away i should basically be using low as fark 45FOV? I think i need to sit closer lol.
From my brief research looks like single monitor = 45-60ish and triple much higher correct?
Edited by UNR33L
Edge motorworks sounds promising
Call and Barry answers
Him: You vont stroker?
Me: Yeah that or an RB30 bottom end
Him: Yah 30 torque monsta...lots of power...do that
I like where this is going
  • Like 5
lol.
I actually heard that in his accent too.
Thought you were going racepace rebuild?
That was the preference but
Last communication to RP was to keep me regularly updated on free spaces in the workshop
2 months later still nothing
I'll pass
No hard feelings from me, but it ain't hard to send a weekly email or knock back the work and say try again in 3 months or something...stringing along is wasting everyone's time when my engine could be getting built right now
They obviously get enough work from their loyal motorsport customers and need to service them as a priority which is fine, but I need to get this thing on the road
Hatish you tried Easey’s burgers yet?
do you rate?
tried Laurie Dee's the Burger adventure winner from last year this week, was very unimpressed.
looking for a new one.
I went to bad boys Melbourne. $15 meal was pretty good value. Tasted great
Took 2.5 hours to drive from sunbury to rowville this arvo.
Mostly due to the Burnley tunnel having a lane closed to half of it for no reason at all.
And then this weekend is going to be spent cursing at the astra.
do you rate?
Yeah, the owner and chef are mates of mine.
I went when it was a popup for a week on the rooftop of an apartment building on bourke st and it was amazing.
If jimmy & josh can keep up that quality then it will be number 1 without fail
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
