Nab is great. Work/life balance is amazing and the culture is very strong. Most people stuck around for a LONG time. We do pay less than the other 3 however generally have higher bonuses
(Which kinda backfires when you we buy failing banks in England and have to provision hundreds of millions then cut bonuses lol)
interesting.
I swore that when I left my current place I would move to a much much smaller company.
would not be IT as per desktop support stuff, moved away from that years ago.
this is a Security Role...
LOL no shit.
I didn't think they were flying you around the world to personally switch it off and then switch it back on again.
  • Like 1
LOL no shit.
actually I have pretty well done this....
well more be onsite whilst they did in case it did not come back up.
  • Like 1
that GTR sounds tuff
also guy in the VL wagon can steer. (considering the way the car is handling)
also dat rotor.
I invited him to the next Sandown day when he asked about it... gave him all the details on how to enter... no dice, would rather just sit on the internet and circle jerk about power figures
I know several people who have worked IT in NAB.
None of them stayed very long, everyone had massive, massive complaints about the structure there and the culture.
Note: This was in level 2-3 support roles. May or may not apply. Enough that I stayed well clear of the place.
In other news, went for a drive with my cracked tank because f**kit YOLO
(will check part numbers at Kudos re R33 and R34 tanks btw)
Split a coolant line
Had to stop about 15 times on the way home to fill up radiator
good times
  • Like 1
Sadly, Mcguyver came in the way of using old liquor bottles to fill up radiator.
Did lol at filling radiator with water coming out of Absolut vodka bottles... x5
Figured that would be Mcguyvery enough. Did get home!
when I split mine.
turned radiator cap one notch back so it realease a bit of pressure and not pump fluid everywhere
made it the 30 km home with only a loss of 500ml,,,
then replaced radiator, hoses, water pump and fan belts, never had a cooling issue again.
when I split mine.
That up there is an excellent idea.
Not in your case Greg, your pistons would probably exit via the exhaust tip. :P
  • Like 1
leeroy played some official race on iracing.. fark me annoying I just kept getting taken out then finished like 11th, nek minit my license goes down a few points because of all the incidents
then I race a 'popular race' not official, come 2nd and it doesn't count toward anything! raging
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
