For reasonably priced Japanese in a laid back bar environment (with good foood and booze) I recommend Hihou in flinders lane. Don't sit near the Windows though, they have these awesome eating sofas at the back of the joint
Cosi, Couldn't recommend due to new ownership.
The new owner's other restaurant is pretty decent though - La Cita
how much you wanna spend per head inc drinks and how fancy?
So fancy you already know
A La Bouffe on Toorak road is a nice little French bar/bistro - you can get steak and chips there and your missus can meddle with the fancier dishes they serve. Wasn't too pricey from memory.
Being French, they have awesome desserts too.
Just looking for something around the south yarra area, not sure maybe <40 a head
Since it's a date you won't be drinking heaps so most places should fit you in for that rate.
I went Morris jones other week on chapel food was good. Probably cost slightly over your budget but we had a lot of drinks
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
