It's not the west dude... Place I worked in South Yarra he was referring to was $40 for a main
Yeah but he is clearly trying to budget else wouldn't stipulate a price at all.
$40 for a main is basically a minimum these days unless your goin local pub on Parma night
No, because people on those shows are not chefs. All they know how to do is copy someone else's idea and try not to f**k it up.
I remember a time when dishes had names on a menu, not just a list of every f**kin ingredient and process involved in making the dish.
Original fillet burger combo up sized
Good: new CEO's partner is a teacher; can't have much more in common with him
Bad: all departments now have KPIs including marketing which is unquantifiable tasks filled with white noise kind if work. Stupidity.
shit marketing one of the easiest to set KPI's on.
track web site impressions, leads generated incoming sales calls.
now in my consulting role, one of my KPI's is that I bill 75% of my time.
only thing is I have no interaction with the sales cycle, marketing or anything that can link to that KPI.
Easy to make KPIs for the department as a whole or the marketing manager.
But we are getting individual KPIs which just doesn't work when we all share the workload around randomly and work comes in randomly streamed down from product dev team and sales team.
e.g. There's no realistic or useful KPI for how good product packaging I design is, or how successful our trade shows are, short of surveying customers and getting a percentage of likes - which we don't do and never will. Worse yet they've hand balled us the task of writing our own KPIs which isn't open to exploitation at all. Dumb.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
