It's not the west dude... Place I worked in South Yarra he was referring to was $40 for a main
Yeah but he is clearly trying to budget else wouldn't stipulate a price at all.
$40 for a main is basically a minimum these days unless your goin local pub on Parma night
No, because people on those shows are not chefs. All they know how to do is copy someone else's idea and try not to f**k it up.
I remember a time when dishes had names on a menu, not just a list of every f**kin ingredient and process involved in making the dish.
Original fillet burger combo up sized
Good: new CEO's partner is a teacher; can't have much more in common with him
Bad: all departments now have KPIs including marketing which is unquantifiable tasks filled with white noise kind if work. Stupidity.
shit marketing one of the easiest to set KPI's on.
track web site impressions, leads generated incoming sales calls.
now in my consulting role, one of my KPI's is that I bill 75% of my time.
only thing is I have no interaction with the sales cycle, marketing or anything that can link to that KPI.
Easy to make KPIs for the department as a whole or the marketing manager.
But we are getting individual KPIs which just doesn't work when we all share the workload around randomly and work comes in randomly streamed down from product dev team and sales team.
e.g. There's no realistic or useful KPI for how good product packaging I design is, or how successful our trade shows are, short of surveying customers and getting a percentage of likes - which we don't do and never will. Worse yet they've hand balled us the task of writing our own KPIs which isn't open to exploitation at all. Dumb.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
