BMW was a loaner from BMW on a ambassador program.
tomic was on P's and got an exception to drive it as it was "work"
got busted doing burnouts BMW took it off him and cops gave him ticket for being a hoon.
few months later he got off p's and bought said Ferrari.
shortly there after went to court re the hoon activity.
lost license.
lols were had.
beers were drunk.
It's also a two way street...you can't expect people to respect you regardless of your position of power if you act like a jack ass. People who say "my game my rules" end up playing alone.
Which is why bosses who don't respect their employees end up with poor employee satisfaction and a high staff turn over. Do it enough and their bosses start asking questions too.
Lot of this Tomic hate stems from jealousy cause young kid with lots of money having a bitch about something...meh...I say good on him, at least he's standing up for himself instead of just prostituting his dignity away for the sake of earning $$$.
Or possibly it stems from when he was given an exemption to drive the M3 on his p's, solely as he was a celebrity and it was "the only form of transport available for him to get to tennis" and he then used it to cruise the strip every day and act like a flog attracting as much attention as possible. Then when the police showed up to pull him up for the 3rd time he refused to stop and instead drove off home and called the lawyers... but not before hiding behind his gate calling the police names, then getting on tv and accusing the police of racially profiling him...
It could also have been that...
Soooo jealous
Looked under my car when it was on a hoist
bad idea
such a bad idea
also, are AD08's still hugely pricey? like $350+ per tyre pricey?
Why not buy Ventus V3? Seem to be $250 a tyre and from all accounts grip better
After my NT05's lasted 7000kms I am now sad.
bad idea
such a bad idea
I think you just had a conversation with yourself
Entirely possible, but was under the impression ventus were waaay more pricey, like, on-par with the AD048R
Given the echo chamber that is VWL, sometimes self-conversations have the same content
bad idea
such a bad idea
why? getting expensive ideas or things not right?
if the same workshops/people work on your car regularly, soon theyll start taking the blame for everything that goes wrong ;)
Nah. Was at scottys. Found out I had 3 bald tyres (1 is brand new and just replaced, woot...), snapped/bent steering/suspension components.....again.. and my exhaust idea had to be massively revisited for another time.
I have a couple of spare new AD08Rs from the import monster AD08R bonanza but love them too much to let them go for as cheap as they did
Solid tyre even at 2012 issue or whatever they were
From what the internets says, the Hankooks go for $250ish and outperform them, the AD08R's go for something like 350 unless you find a deal.
Almost bought the guy who was selling 2x for 500 awhile back (ad08r's)
Just knew my rears were worn, but on the indicators after 7500kms on NT05's was.. yeah. I suspect the Hankooks last about half as long as the AD08R's. Hence the query about them before HWP says HEY MATE BALD TYRES OFF TO DEFECT LAND and which they would be correct to do so.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
