nope shitter cheaper and pushed out end date to 2019 to upgrade to the technology that you already had.
basically if you can get over 25 megabit connection, (adsl2+ or cable) then you already have internet that is too fast (after all there no need for internet that fast unless your doing something illegal) so you are not a priority
so their massive upgrade of system was to decide that we should all upgrade to technology that been around for 10 years.
rather than push out fibre to the premise that is next gen tech..
So i thought I'd sign up to this NBN jive as i want faster net and it's getting quite cheap now...
NOT f**kING AVAILABLE IN MY f**kING AREA. f**k. I LIVE IN f**kING BRIGHTON NOT f**kING CAPE YORK FOR f**kS SAKE. HOW THE f**k? THERE ISN'T EVEN A PROPOSED DATE FOR MY AREA! WHAT THE ACTUAL f**k.
I live in Boronia and I can't even get ADSL2 or cable...no date set for NBN as far as I know
Telstra's solution was to change my bill to say ADSL instead of ADSL2 which they sold me, so that it doesn't look like they're selling me a service I'm not getting
Telstra told me cable wasn't available at my new place in Clayton.. got my brother there to check it out (works for Telstra and installs it) and all was good.. installed it said bitch activate my modem (after many hours on the phone)
Eventually got it sorted out
Can you seriously get your brother to put me into an ADSL2 port
I know they have them at the exchange but Telstra refuse to use them
Depends how much cash you pay him ;)
Yeah he does stuff like this I think he's unplugged other people from the exchange to fix issues at other customers sites lol
My internet is pretty terriblre in rowville and all I get is "exchange is full on a first-in-best-dressed scheme so you get sloppy seconds"
Might give them a call today to "negotiate" a new price.
I will pay him handsomely in cash if he can get me ADSL2
Unlimited Optus Cable in Altona Meadows is where it's at. 5-10mbps on Utorrent is the standard.
yeah it was a hard call when I have optus and telstra cable run past my house.
which 100 Mbit do i want to go with.
Optus naturally.
feels good knowing most speed issues are on the server end not mine.
I get 110mbps on my phone, in my shed, with 3 bars of service. How is that cable service good? :P
So do I but I can't download 200gb worth of shit a month. 1 movie would fill my limit haha.
I don't know anyone that can download movies at 7mbs+.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
