nope shitter cheaper and pushed out end date to 2019 to upgrade to the technology that you already had.
basically if you can get over 25 megabit connection, (adsl2+ or cable) then you already have internet that is too fast (after all there no need for internet that fast unless your doing something illegal) so you are not a priority
so their massive upgrade of system was to decide that we should all upgrade to technology that been around for 10 years.
rather than push out fibre to the premise that is next gen tech..
So i thought I'd sign up to this NBN jive as i want faster net and it's getting quite cheap now...
NOT f**kING AVAILABLE IN MY f**kING AREA. f**k. I LIVE IN f**kING BRIGHTON NOT f**kING CAPE YORK FOR f**kS SAKE. HOW THE f**k? THERE ISN'T EVEN A PROPOSED DATE FOR MY AREA! WHAT THE ACTUAL f**k.
I live in Boronia and I can't even get ADSL2 or cable...no date set for NBN as far as I know
Telstra's solution was to change my bill to say ADSL instead of ADSL2 which they sold me, so that it doesn't look like they're selling me a service I'm not getting
Telstra told me cable wasn't available at my new place in Clayton.. got my brother there to check it out (works for Telstra and installs it) and all was good.. installed it said bitch activate my modem (after many hours on the phone)
Eventually got it sorted out
Can you seriously get your brother to put me into an ADSL2 port
I know they have them at the exchange but Telstra refuse to use them
Depends how much cash you pay him ;)
Yeah he does stuff like this I think he's unplugged other people from the exchange to fix issues at other customers sites lol
My internet is pretty terriblre in rowville and all I get is "exchange is full on a first-in-best-dressed scheme so you get sloppy seconds"
Might give them a call today to "negotiate" a new price.
I will pay him handsomely in cash if he can get me ADSL2
Unlimited Optus Cable in Altona Meadows is where it's at. 5-10mbps on Utorrent is the standard.
yeah it was a hard call when I have optus and telstra cable run past my house.
which 100 Mbit do i want to go with.
Optus naturally.
feels good knowing most speed issues are on the server end not mine.
I get 110mbps on my phone, in my shed, with 3 bars of service. How is that cable service good? :P
So do I but I can't download 200gb worth of shit a month. 1 movie would fill my limit haha.
I don't know anyone that can download movies at 7mbs+.
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
