And this is probably close to as responsive as possible for the power made on a R34 GTT factory RB25det Neo, running newly developed ATR43SAT BB internally gated bolton turbo on P98 fuel. 317rwkws @21psi, 20psi @ 3550RPM.
  • 2 months later...
Why do most of the dyno grahs show power fall over at the top end?
Because most people run along the edge of the compressor efficiency curve. This means they get max turbo airflow in the midrange and also in the top end. If you get similar airflow at 5000rpm as you do at 8000rpm then this means reduced torque as you are sharing the same air over more combustion events, reduced torque means reduced power.
Most factory turbo cars don't smash the boost in the midrange or max the turbo out, hence they can hold flat torque to redline. If they didn't then you'd see the typical huge midrange torque and dropping off at redline.
Tao, what is the expected results on an RB25DET? Considering swapping my turbo out for a smaller one for less lag.
If I drop the exhaust or run external gate, top end torque curve would be more flat. For a good turbo configuration on a good internally gated setup. On pump fuel, The torque curve is usually an umbralla shape.
ill be running the non bb version of the 43sat iwg on my car, hoping to tune it next weekend yet that will depend if a part i ordered tonight gets here in time, if it doesnt then whatever day it gets here ill throw it on my dyno and see how it goes. stock rb25, 3"tbe, fmic, so that should give you a better idea if you can wait a week or two
  • Like 1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
