59 minutes ago, BakemonoRicer said:
Dose, AI didn't make the cut, their surge tanks are too small, look at the volume those pumps take up, damn near the whole canister. I had no choice but to go big spec with aircraft grade alloy and 10L volume.
Gonna be needed to keep the fuel cool when I'm full tilt at wakefield coming in hot through the kink, should help with a bit of weight over the rears to keep me planted.
Micko, no Elixir in main tank, I would of needed a billet cradle for that puppy so for once I didn't spend the dollars. Leaving the Nismo lift pump in there.
A single intank 460 would have been fine considering stock glass gearbox and stock bottom end. ?‍♂️
The car is at insight now to get kuhnerized!
it's the grand daddy s15 this is the result of 8 years of NASA development
basically light years of research to develop the ultimate street S15
feels good to be off the drawing board and in the pilots seat soon
  • Haha 3
Say hello to 243kw & mountains of 6 speed busting torque Benny!
I reckon NASA would almost consider taking the astronauts out to the lift for the shuttle in this thing mate!
It's gunna be WILD bro!
Imagine doing 0-100 in 4.9 seconds?!
Imagine a guy in a space suit in your drivers seat?!
Imagine if he farted in that space suit in your car in your drivers seat?!
Imagine the stories you can tell your Latina grandchildren in the Favela?!
Exciting times bro....... EXCITING TIMES!
Edited by Mick_o
  • Like 1
I think you're trying to say you want to buy my leftover fuel system parts....
I give you good deal, as long as you admit I'm the fuel system king.
Haha my fuel system is done. It's only a Pleb spec Radium hanger and twin 525s unfortunately. But it delivers the fuel I require and I don't have a boot full of junk ?‍♂️
Hahaha I love that you can leave this forum for 8 years, and come back to find nothing has changed. GTSBoy is still the crankiest Guru in the RB world, nobody searches before posting, and Benji is still talking shit like no one else can ?
  • Like 1
  • Haha 1
Nah, it was being tuned at a decent shop, it'll be fine. Sure the result won't be earth shattering, but I'd think they'd just cap the power at the obvious safe limits.
Hopefully he didn't say - keep pushing it til it runs out of fuel system 0_0
  • Like 1
The EFR speed sensor is the limit not the fuel system (its an obvious Stage 4 1000hp+ setup).
This build doesnt contain the sentence.... "let's play it safe".......
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
