  • 5 weeks later...
40 minutes ago, Dose Pipe Sutututu said:
Going Wakefield 14th September, you come. We'll see who shreds a gearbox 1st.
Eh, I'm all about roll racing now ....
a lot easier on the car than drag/circuit, don't have the money or willingness to break things like you do lol
My car is full of cheap non-NASA spec parts, hence can afford to push it right up to the limits and over too.
I'm sure I'm over speeding that Garrett non-NASA spec turbo, oh wells ?
Don't you need Samsonas to participate in Roll Racing now?
  • Like 1
  • Haha 1
Minimum requirements:
  • 500kW at the rear
  • Samsonas
  • Full crew with same shirts
  • Like 1
  • Haha 6
  • 3 weeks later...
Got behind the wheel of the Don Mega S15 at Roll Racing
Scooted down the track for 5 passes then had to head off to work
Still getting a feel for the car as it's spinning tyres and I'm sliding around...
I definitely got the soundtrack right on this puppy!!!!
  • Like 2
1 minute ago, admS15 said:
Must have got the danger to gearbox warning light.
What I find hilarious is that, everyones prediction was I'd blow the box....and funnily enough, the box is still absolutely great.
I think my cognisance relating to mechanical sympathy does play a part in the fact NOTHING on my cars goes wrong.
Meanwhile, everyone else is blowing 6 speeds and throwing rocker arms, I'm calling it that more "they don't know how to drive".
Good to see you got out there.
Mechanical sympathy and not shocking the gearbox will definitely help longevity. If torque/ignition curve isn't too aggressive that will help.
Apart from killing a Nismo twin plate in bumper to bumper traffic with stock turbos?
  • Haha 1
Clutch slip will protect a gear box so history checks out!
  • Haha 1
can you post the pic of the car spinning tyres and sliding around? i watched the video 6 times and all i saw was about 10 seconds of coming onto boost?
  • Like 1
  • Haha 1
Please, if you have any doubts let’s line up player
I’m yet to see any videos of your car light it up, come step to the plate ; )
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
