Here's the setup I am currently running.
Power is a tad over 900awhp or 671kw's @ 30 PSI of boost on E85
PB of 8.97sec at 150mph makes it 2nd Fastest Street Tyred Manual Gearbox GTR in the World
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Jun 295 degree x 11.8mm Lift
-Full Tomei Valvetrain.
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-2000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
-5 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
Here's what 8sec with H-Pattern Looks like. :yes:
  • Like 1
When it got weighted at Jambo it tipped scales at 1440kg that's was with half tank fuel and no driver. Car has all factory glass and steel panel except the bonnet. So pretty much weighs same as a stock R32 which is a surprise lol
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Could we bother you for a dyno sheet with RPM on the bottom axis? It would be most appreciated!
It runs a stock standard RB26 bottom end, not N1 block...
Yes, we ran a 10.3 @ 142mph last night - first run out of two, first time it's ever been raced down the quarter with the sequential & over 600hp...
Bogged down at the start too. In full street trim - 20" rims with shitty Hero tyres.
This car weighs around 1700kgs including the driver & massive brakes.
Will post up vids of the run tomorrow :)
How long is it going to last at that power??? Who knows!!! It's been on over 600awhp for nearly 2 years now, stepping it up to 800+ early September this year. Has done Powercruise Bris, Powerplay Syd, SAU airport runs & 2 runs last night. Yes, we have a 3.2 that's almost ready to go in :)
If you want dyno graphs, various vids etc. then check out our Mercury Motorsport Youtube channel ;)
    • Physically, you'd expect it to turn the motor 11/8ths faster than a standard one, but I'm not sure of specifics
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
