Ok so my diff guy has gone missing...  I'm trying to get my stuff back so I can start re-assembling things.  I'm hoping he's just gone away for the Chrissy break (and have no issues with that being the case!) but I really wanted to get stuck into it while there are a few days off here and there over the Chrissy/New Years break even though I'm working through.
My GKTech camber arms turned up yesterday so I can whack them in once the new upper control arm bushes arrive.
While all the front suspension is apart to remove the front diff I'll give everything a really good clean up under the front wheel arches to get rid of some of the 24 years of built up crud!  One day I'd love to do a full resto job on the car but I want to get it up and running and enjoy it for a while first.  The body is in great condition, it's just the bolt ons (bumpers, side skirts, boot spoiler, etc) that are in need of some love.  I've never played with bolt ons so should be fun..... oo > 00
I've spent a few hours modifying the front bumper to accomodate the 100mm intercooler.  I've had to hack off a good inch here and there to get it all to fit.  I found the front reo to be really out of whack too.  The bumper has always been on crooked so I was determined to get it right.  I elongated the holes on the mounts, bent the top bumper guide edge (the section that sits under the headlight to hold the front edge of the bumper) and also bent the whole reo bar across to the passenger side a bit.  It all sits perfect now so well worth the few hours of stuffing around!  It's probably never been right for its whole life!
Plenty of other things I could be doing but due to the time of year it is and my cyclic motivation, not much is getting done!
In the times I should be out in the 45 degree shed I've been watching all of this series which is well worth a watch if you haven't already.  The kid is only 20 years old but this is already the second car he's done a full body resto on.  He's done a brilliant job and is very honest with his mistakes.  Well worth a watch if you're planning on getting stuck into your own car but just need a bit of assurance to have a crack!  He mentions something that I've spoken of before that the hardest part of performing modifications is just starting.  Once you start you've already conquered the first and hardest hurdle.  Give it a look-
  • Like 1
My diff guy finally poked his head back out yesterday so I can go and pick up the diffs.  I'm not actually sure if he has done anything with them, will hopefully find out today.
Otherwise I've just been fluffing around to be honest.  Just doing little bits and pieces but not much!  I gave the wheel arch areas a clean up as they were very dirty as you'd expect.  The paint is VERY thin under there so had to back off a bit once I started going through the paint....  Once the diff is re-assembled I can whack the new camber arms in and re-assemble it all.  I really want to do a full resto job on it but I'll fight off the urges and do it down the track.  I'll just clean up what i can and be done with it.  I'm putting a new set of lower ball joints in while it's all apart as the boots are split on one and very perished on the other.
Front diff housing is all cleaned out ready to re-install the diff when I get it back.  I've machined a little bit off the inside of the diff housing to make getting the diff back in a little easier.  They're a bastard of a thing to get in and out while in the car so anything to make it a bit easier is a bonus!
Cleaned up all the bolts in the ultrasonic cleaner, it does an awesome job (see pics)!
As a side job I built a very quick, slapper trolley to hold my sandblaster unit as doing it on the ground was not great for my knees and my back!
I'm resto-ing the front grill mesh so stripped it apart and have started sandblasting the powdercoat off the mesh.  It's bloody hard to get off.  I tried paint stripper but it does nothing to powdercoat I now discover!  More time in the sandblaster and they'll be all good.  not sure if I'll just paint them or go powdercoat again.
Even though I'd done it before I gave the headlights another hit on the buff to bring them back to sparkling.  One day I might actually get to use them!
Starting to contemplate getting the fibreglass kit out again to fix a few bits and pieces but I'd rather keep that till after it's back on the road.  See photos of cracked boot spoiler brake light surround.  Gunna be tricky to fix....
Hopefully getting the diffs back will get me motivated again!
  • Like 3
@georgev cheers for the kind words. It's become quite a lengthy read so you've done well!
Diffs are back. Both are in great condition which is good news and bad news! I'm glad it's now eliminated as an issue but it means we've still got a problem!
I'll re-assemble the front diff then get the car trailered back to the diff guy so he can set up the whole thing perfectly. He'd really rather me take the sump off and give that to him..... I'm not convinced I can be effed doing that! ?
Will hopefully get back into it over the weekend.
  • Like 1
2 hours ago, Looney_Head said:
yay for good news, gutted its not the issue :(
Yeah bit of a bugger....
Maybe I'll just ditch the front drive line and make it into a RWD drift pig!
lol as a person with a high hp rwd, i would strongly advise against that lol, unless its just for a little bit of time.
i have to wait till 4th and 5th to give mine 20psi lol
Yeah there would be a massive 'skills actual' versus 'skills required' variance if I tried to drive it in RWD.  I need AWD to be any chance of keeping it pointed in the right direction (not upside down)!
  • Like 1
Somewhere between "I won't bother cleaning it, I'll do it another time" and "I may as well give it a quick clean" I took a wrong turn... 4 hours hunched over the parts washer with bloodied, cut up, and bruised hands I ended up with some pretty bloody clean front suspension!
It was all done with a scouring pad and elbow grease.
Not really progress and bloody hard work but had to be done!
Doing little things like this will hopefully keep me ticking things over so when the bug bites again there are no major obstacles.
Spent more time on shed modifications this week than working on the car.
Too much junk in my shed so adding a new section to make more room. Maybe room for another project.... Maybe.
  • Like 2
Apologies this post is extremely pic heavy!  A little bit of catching up to do!
Still just fluffing around with minimal drive!
More cleaning of the front suspension so it all looks nice. I'm now going to replace the lower inner ball joint as well as the lower outer. The only one I won't do for now is the upper outer big bastard that is a dog of a job that I'll avoid for now...
On other goings on I bought a cheap metal band saw for cutting pipe easier (maybe....). Impressions so far are TBC. Hopefully it's only the cheap blade that came with it but I've already broken a blade after about 10 or 12 cuts of 4" stainless. I'll order in some new blades and hopefully get a better result.
I did manage to get enough (10) pie cut sections to be able to make a lobster back 90 degree bend.
I decided that the car is too loud so thought I'd give a Varex Muffler a go. It's the biggest one they make being 4" in and out. I'll try and fit it without having to modify the exhaust so I can reuse the other Muffler if it turns out shit. It's a tiny outlet in closed position so will knock a heap of power out but hopefully nice and quiet.
Can someone help identify my front LSD? I've googled a heap of pictures but can't find one the same. I'm thinking maybe Cusco but not 100% on that. There are also some similarities with the OS Giken but I don't think it's one of them.
Painted up some other bits and pieces to make them look pretty. These are the mid car chassis braces-
I also decided to pull the box out to make sure everything is all good in the clutch area.  Plus I want to pull apart my transfer case to make sure I haven't done anything wrong there.  Once the front diff is re-assembled and I've checked over the transfer case hopefully I've eliminated everything that could have caused my noises!  I forgot how much of a dog of a job pulling the box out is!  Every other time I've pull the whole thing out as a whole unit (down through the bottom).  You guys doing it on the ground are now my heroes!  I bought a jack transmission cradle that I couldn't be bothered waiting for.  I'm going to try and mount it to my engine crane to be able to use it up in the air as opposed to on the ground.  I'll see how that turns out...
This is a spare (broken) box I bought that has a pre-modified transfer case.  I might use that one if i start to doubt mine too much!
Ground out a bit of material from the front diff housing to make re-install a bit easier.  All cleaned out ready for re-install-
Again it's a slow burn on my enthusiasm but we're slowly but surely getting there!  Probably aiming to have it all back together mid Feb.  If not, what's another month or two!!  :)  :( .
  • Like 3
Shoota, I’ve got that varex on my car, it’s really quiet when closed, I’d recommend you hard wire a switch in the car to open/close it as the remote is a pain in the arse!
Edited by Old man 32 GTR
  • Like 1
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
