Ok so my diff guy has gone missing...  I'm trying to get my stuff back so I can start re-assembling things.  I'm hoping he's just gone away for the Chrissy break (and have no issues with that being the case!) but I really wanted to get stuck into it while there are a few days off here and there over the Chrissy/New Years break even though I'm working through.
My GKTech camber arms turned up yesterday so I can whack them in once the new upper control arm bushes arrive.
While all the front suspension is apart to remove the front diff I'll give everything a really good clean up under the front wheel arches to get rid of some of the 24 years of built up crud!  One day I'd love to do a full resto job on the car but I want to get it up and running and enjoy it for a while first.  The body is in great condition, it's just the bolt ons (bumpers, side skirts, boot spoiler, etc) that are in need of some love.  I've never played with bolt ons so should be fun..... oo > 00
I've spent a few hours modifying the front bumper to accomodate the 100mm intercooler.  I've had to hack off a good inch here and there to get it all to fit.  I found the front reo to be really out of whack too.  The bumper has always been on crooked so I was determined to get it right.  I elongated the holes on the mounts, bent the top bumper guide edge (the section that sits under the headlight to hold the front edge of the bumper) and also bent the whole reo bar across to the passenger side a bit.  It all sits perfect now so well worth the few hours of stuffing around!  It's probably never been right for its whole life!
Plenty of other things I could be doing but due to the time of year it is and my cyclic motivation, not much is getting done!
In the times I should be out in the 45 degree shed I've been watching all of this series which is well worth a watch if you haven't already.  The kid is only 20 years old but this is already the second car he's done a full body resto on.  He's done a brilliant job and is very honest with his mistakes.  Well worth a watch if you're planning on getting stuck into your own car but just need a bit of assurance to have a crack!  He mentions something that I've spoken of before that the hardest part of performing modifications is just starting.  Once you start you've already conquered the first and hardest hurdle.  Give it a look-
  • Like 1
My diff guy finally poked his head back out yesterday so I can go and pick up the diffs.  I'm not actually sure if he has done anything with them, will hopefully find out today.
Otherwise I've just been fluffing around to be honest.  Just doing little bits and pieces but not much!  I gave the wheel arch areas a clean up as they were very dirty as you'd expect.  The paint is VERY thin under there so had to back off a bit once I started going through the paint....  Once the diff is re-assembled I can whack the new camber arms in and re-assemble it all.  I really want to do a full resto job on it but I'll fight off the urges and do it down the track.  I'll just clean up what i can and be done with it.  I'm putting a new set of lower ball joints in while it's all apart as the boots are split on one and very perished on the other.
Front diff housing is all cleaned out ready to re-install the diff when I get it back.  I've machined a little bit off the inside of the diff housing to make getting the diff back in a little easier.  They're a bastard of a thing to get in and out while in the car so anything to make it a bit easier is a bonus!
Cleaned up all the bolts in the ultrasonic cleaner, it does an awesome job (see pics)!
As a side job I built a very quick, slapper trolley to hold my sandblaster unit as doing it on the ground was not great for my knees and my back!
I'm resto-ing the front grill mesh so stripped it apart and have started sandblasting the powdercoat off the mesh.  It's bloody hard to get off.  I tried paint stripper but it does nothing to powdercoat I now discover!  More time in the sandblaster and they'll be all good.  not sure if I'll just paint them or go powdercoat again.
Even though I'd done it before I gave the headlights another hit on the buff to bring them back to sparkling.  One day I might actually get to use them!
Starting to contemplate getting the fibreglass kit out again to fix a few bits and pieces but I'd rather keep that till after it's back on the road.  See photos of cracked boot spoiler brake light surround.  Gunna be tricky to fix....
Hopefully getting the diffs back will get me motivated again!
  • Like 3
@georgev cheers for the kind words. It's become quite a lengthy read so you've done well!
Diffs are back. Both are in great condition which is good news and bad news! I'm glad it's now eliminated as an issue but it means we've still got a problem!
I'll re-assemble the front diff then get the car trailered back to the diff guy so he can set up the whole thing perfectly. He'd really rather me take the sump off and give that to him..... I'm not convinced I can be effed doing that! ?
Will hopefully get back into it over the weekend.
  • Like 1
2 hours ago, Looney_Head said:
yay for good news, gutted its not the issue :(
Yeah bit of a bugger....
Maybe I'll just ditch the front drive line and make it into a RWD drift pig!
lol as a person with a high hp rwd, i would strongly advise against that lol, unless its just for a little bit of time.
i have to wait till 4th and 5th to give mine 20psi lol
Yeah there would be a massive 'skills actual' versus 'skills required' variance if I tried to drive it in RWD.  I need AWD to be any chance of keeping it pointed in the right direction (not upside down)!
  • Like 1
Somewhere between "I won't bother cleaning it, I'll do it another time" and "I may as well give it a quick clean" I took a wrong turn... 4 hours hunched over the parts washer with bloodied, cut up, and bruised hands I ended up with some pretty bloody clean front suspension!
It was all done with a scouring pad and elbow grease.
Not really progress and bloody hard work but had to be done!
Doing little things like this will hopefully keep me ticking things over so when the bug bites again there are no major obstacles.
Spent more time on shed modifications this week than working on the car.
Too much junk in my shed so adding a new section to make more room. Maybe room for another project.... Maybe.
  • Like 2
Apologies this post is extremely pic heavy!  A little bit of catching up to do!
Still just fluffing around with minimal drive!
More cleaning of the front suspension so it all looks nice. I'm now going to replace the lower inner ball joint as well as the lower outer. The only one I won't do for now is the upper outer big bastard that is a dog of a job that I'll avoid for now...
On other goings on I bought a cheap metal band saw for cutting pipe easier (maybe....). Impressions so far are TBC. Hopefully it's only the cheap blade that came with it but I've already broken a blade after about 10 or 12 cuts of 4" stainless. I'll order in some new blades and hopefully get a better result.
I did manage to get enough (10) pie cut sections to be able to make a lobster back 90 degree bend.
I decided that the car is too loud so thought I'd give a Varex Muffler a go. It's the biggest one they make being 4" in and out. I'll try and fit it without having to modify the exhaust so I can reuse the other Muffler if it turns out shit. It's a tiny outlet in closed position so will knock a heap of power out but hopefully nice and quiet.
Can someone help identify my front LSD? I've googled a heap of pictures but can't find one the same. I'm thinking maybe Cusco but not 100% on that. There are also some similarities with the OS Giken but I don't think it's one of them.
Painted up some other bits and pieces to make them look pretty. These are the mid car chassis braces-
I also decided to pull the box out to make sure everything is all good in the clutch area.  Plus I want to pull apart my transfer case to make sure I haven't done anything wrong there.  Once the front diff is re-assembled and I've checked over the transfer case hopefully I've eliminated everything that could have caused my noises!  I forgot how much of a dog of a job pulling the box out is!  Every other time I've pull the whole thing out as a whole unit (down through the bottom).  You guys doing it on the ground are now my heroes!  I bought a jack transmission cradle that I couldn't be bothered waiting for.  I'm going to try and mount it to my engine crane to be able to use it up in the air as opposed to on the ground.  I'll see how that turns out...
This is a spare (broken) box I bought that has a pre-modified transfer case.  I might use that one if i start to doubt mine too much!
Ground out a bit of material from the front diff housing to make re-install a bit easier.  All cleaned out ready for re-install-
Again it's a slow burn on my enthusiasm but we're slowly but surely getting there!  Probably aiming to have it all back together mid Feb.  If not, what's another month or two!!  :)  :( .
  • Like 3
Shoota, I’ve got that varex on my car, it’s really quiet when closed, I’d recommend you hard wire a switch in the car to open/close it as the remote is a pain in the arse!
Edited by Old man 32 GTR
  • Like 1
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
