? Isn't it ? Yep just a raised up pallet, so something you can put the centre plate on, have the long front sections of the shafts pointing down while you're tapping them out. Easier than trying to tap them out sideways when the centre plate and geaset is mounted in a vice.
Finished the teardown and rebuild on the old man's box and transfer case modification yesterday. A photo I thought you might find interesting proof of why not to use any smooth shift additives or anything but GL-4 oil in a GTR synchro box. This is a synchro from 1st, it is completely stuffed and has been attacked by incorrect oils being in the box. Nulon and Penrite additives are terrible for doing this. The new one is the shiny one obviously, and the discoloured one actually has some parts of the synchro teeth missing also.
The gear also had a lot of synchro teeth missing, all stuck to the box drain sump plug.
  • Like 1
  • 1 month later...
A few minor updates.
New 3rd gear and press on sleeve finally arrived from Amayama. Corona making a (unt of itself again...
Front diff should be back in a week or so from the dude who is resetting it in the sump for me.
I tried BK's method of removing the shafts from the centre plate and had mixed results... The counter shaft went from staying in place after 20 hits with the dead blow hammer to launching itself out and smashing into the synchro on the mainshaft and smashing it in half ?‍♂️.  I decided to keep trying with the mains haft but ended up destroying my dead blow hammer which disintegrated in a shower of ball bearings and metal dust..   BK, you can stick your bloody method! ??
Went back to the original plan of modifying the press to finish it off. Seeing I bought the bloody thing primarily for that purpose I may as well use it!
I cut the deck in half then cut up some steel plate to weld it back together. I made it 120mm between each side which is big enough to fit the largest synchro on the mainshaft in between them.
I also drilled new holes on the middle of the deck to be able to support it from two points on the uprights rather than just the one. Seeing the deck is now wider it puts a lot more load on the pins.
Cue more boring press modification pictures!
As soon as the mods were finished i threw the mainshaft and centre plate in the press and off it came with minimal effort!
Building my new mower shed next weekend so I can get my machining/welding/grinding shed up and running.  It'll be great to get all of that stuff out of main shed.
Slowly slowly!
  • Like 1
1 hour ago, BK said:
I can't believe you had so much trouble getting the shafts out ?! Anyway good to see you're progressing !
Yeah I dunno, it just had it in for me!  I'm not sure if it was because it was a pretty new gearbox??  Anyway, all good.  It's heading in the right direction now!  Once I get this shed out of the way I'm back into it!
Boring shed pic-
3 minutes ago, Ben C34 said:
true, boring pic. Back to press mod pics please!
Ha ha, sorry they're all boring non car related posts lately!  Hopefully in a few weeks that will change a little bit......
  • Like 1
Hi mate, very kind words, thankyou.  I'm glad you're enjoying what is possibly the slowest build on the whole of SAU :).
I can feel the motivation juices slowly churning away again so fingers crossed I can start to get into it again.  If we end up going back to shorter hours here at work again (due to COVID) then there's a chance I'll have a bit more extra time to work on it again!
*eagerly waits for bathroom and kitchen reno posts*
OR
SAMSONAS
  • Like 1
OR
SAMSONAS
House is only 6 years old so renos are years away!
Ha ha, put in a pool for the kids or get a sequential.... Hmmmmm.
Sequential will be cheaper!
18 minutes ago, Ben C34 said:
Kids will swim in pool 15 times a year max once novelty wears off after first year.
you will drive the car maybe more than that a year?
This man here makes a valid point, you would definitely drive the car at least 16 times a year. So in conclusion, get a sequential box.
Jesus that escalated since the last time I checked in ??.
16 swims a year versus no drives for 8 years. The pool is looking like the smarter option at this point!
I’d need to sell the car to afford either of them which would make one of the choices a redundant decision.....
  • Like 1
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
