  • 2 months later...
Just received my new 2860-5' and Haltech ECU( with antilag/lauchcontrol etc- :whistling::whistling: ) and an Exedy Pupp type ceramic twin plate clutch
and lightened flywheel kit.. :yes::yes::yes: ..
I now have the following for sale:
1 x power FC with hand controller( replaced with new Haltech)
1 x OS Giken twin plate/lightend flywhwheel package( 3000 klm old only)**** not strong enough for new HP set-up
1 x set of N1 wizzers in good nik..
Its taken nearly 2 years to start from scratch.... and its just about there......and I can hardly wait !!!!
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
Guy's,
I have just checked my "messenger" and there has clearly been some interest in my OS&G twin plate package
whilst i have been away...please see pics attached fyi
post-74499-0-21950500-1410261906_thumb.jpgpost-74499-0-34635600-1410261981_thumb.jpgpost-74499-0-90428000-1410262047_thumb.jpgpost-74499-0-88594700-1410262095_thumb.jpg
I bought this OS&G complete package for around $2300 and did about 4000klm with it( tarmac rally and circuit klm's)
I have stepped up to a new ceramic set up based on the new 600 ish HP forecast for this new build.
This package would suit up around 400 HP and both clutch plates have plenty of life( 3.85mm and 4.00mm thick) and could go straight back into a streeter
As can be seen it has seen a bit of heat but no big issue for the price.... happy to move the whole package at a third of the price....pm me if you are interested( the entire new build of this car has not been cheap, so any cash form previous parts will assist......
cheers
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
  • 4 weeks later...
CAMS scrutineering now complete and "rego"..... this week.\
Just spent the day applying the old skool decals purchased from GMS..
Finally i can drive this sucker....after.3 long years starting from scratch!!!
post-74499-0-61263100-1423395049_thumb.jpgpost-74499-0-45727000-1423395096_thumb.jpgpost-74499-0-37202600-1423395116_thumb.jpgpost-74499-0-48335600-1423395144_thumb.jpgpost-74499-0-17714100-1423395194_thumb.jpg
  • Like 2
Got a paperwork issue with CAMS but will have it sorted in the next couple of weeks, so no barbagallo next week :down::down:
But took it for my first drive today under a permit...( around 20klm's)
Man its stout-as :yes::yes::yes::yes::yes::yes:
  • Like 2
  • 1 month later...
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
