ahh cheers dude. Yeah my kando lines are fine as far as i can tell. They also sent me the wrong size banjo fitting first time round haha.
I got my package last week from Kando, mofo sent me the wrong crush washers lol.. 2x too many medium ones and 2x short for the smaller ones...
Still waiting on my hypergear turbo... [haz a gate mounted on it] wooooo
  • 3 months later...
So no updates in a while. Good news is my compression test was all between 167-170.
Bad news is latest test shows 161,155,140,150,144,113. I am suspecting that the head is warped, don't think the headgasket could be that rooted all round could it? Warped head means throw away yeah or is it able to be machined true again and i will just run a slightly thicker headgasket to compensate? Either way bad news.
But the good news is that i have 2 RB30 bottom ends sitting in the shed waiting for me to pull the engine out :)
Should also say that i did do 4 track days with the NEO in and it was amazing to drive. It never missed a beat until i got to Winton for the matsuri this year and it did nothing but overheat. Flushed (forwards and backwards) the engine and radiator, took the thermostat out, front bar off, replaced radiator and nothing could keep it cool. Once it got over 100deg it would just keep going to 120+deg.
Cool down laps (fast and slow and varying RPM) spraying water over the intercooler and radiator, pouring water on the radiator. Nothing could bring the temp down except shutting it down and leaving it sit.
I pretty much decided i wasn't going to drive 20 hours to not drive so i thrashed it as hard as i could until it started to overheat (maybe 4-5 laps a session) so i can't say it didn't treat me well, i was giving it hell. Not showing any signs of a f**ked headgasket. No oil in water or bubbling radiator, just the low compression. It still idles fine and drives fine, obviously you can feel its substantially down on power but still gets up and goes when it comes onto boost.
Anyway, the general plan in RB25/30 NEO, 6BOOST high mount, 45mm Turbosmart gate, Hypergear SS2, Greddy FFP, Xspurt 1000cc, E85.
Yeah i know that that is what made me suspect head gasket in the first place, i just meant no other signs, usually you get the overheating, oil/water mix and bubbling in your cooling system.
Yeah me too for the same reason haha. I was going to do a leak down test but in the end i decided i will take the time to do everything properly and the way i wanted it. Before i wanted to keep it with standard plenum and manifolds with low mount internal gate. But i decided with the height the car sits at and being able to see the roll cage through the rear window, if i get pulled over i will be getting defected anyway, not much i can do to hide it.
May as well go and make it an all out track car now and drive it until rego expires or the boys in blue catch up with me haha. I was thinking about it today as well, when i replaced the manifold studs the second time i forgot to hook the wastegate actuator up and i took it for a drive. I was watching all my guages when i went WOT but i saw the boost spike to 2.4 BAR (35psi) and ever since then i have had the overheating issues. Is a single spike like that enough to lift the head? If so it explains a few different things.
I am really hoping that the head just got lifted and hasn't warped at all.
Yerp, I know that from personal experience... Stock VQ's don't like 50+ psi apparently. :P
A set of ARP or oversized bolts and a new MLS head gasket should have you up and running again, unless it leaned out severely...
My stock NEO is still holding up after countless days of abuse, just recently we decided to screw ARP head studs in one at a time so the engine stayed sealed, just for safety! Have had a boost spike similar when i blew the bottom gate line off and its still good :)
I have a spare Neo sitting in my shed, and 2 RB30 blocks. I'm going to put one Neo head on an unopened block and see how it goes. I'll also slowly rebuild the other 30 and just wait for the first one to go pop.
RB25/30 Neo, Hypergear SS2, External gate, 6Boost, Greddy FFP, X-Spurt 1000cc injectors, Adaptronic, E85.
That's the general plan :)
  • Like 1
Got the head skimmed in preparation for Cometic MLS head gasket, apparently the head was pretty much dead straight, good news! The machinist removed 4-5 thou so not enough to effect compression really. Will be running a standard size (1.3mm) head gasket.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
