Mirror I disabled. The video input is missing to it. I know WHERE it is in radio as I have the manual for the car but not entirely sure where it is on that car without a lot more time and prodding. If you look closely in the rear camera you will see two systems there. The camera controller on the 2008 is still showing under the 14 one that the radio provides. I could kill the lines in set up but it breaks other things doing so.
I widened the radio lines as they were off center and too narrow.
I checked this out at SEMA today, only designed to work with non navi G37, will definatly NOT work with any JDM 370GT, also i personatly would not replace my std parts with this, it would be lowering the std of the car.
The screen that's not factory is an external Miracast box which can have an android phone mirrored to it. Most of them just use the AV inputs so are pretty bad quality wise - and if you don't have the handbrake bypass then you can't have Nav from your phone onscreen while driving.
I still can't believe that there's a software upgrade available to convert to English that's basically pirating and it's so closely controlled and costs a fortune. So frustrating.
Cheers - N
Any of the CDN items are. Straight swap.
That said you can also get a USDM one same swap the centre display out of it into the jap one as well. You still need to buy the full USDM cluster though.
  • Like 1
Thanks Chris.
Does it need to be the same year model or could you drop say a 2011 CDN unit straight into a JDM 08?
Curious as i prefer the newer dash with the white in the centre rather than the red from the earlier models.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
