There is a setting for metric in there. Use that and everything changes.
Hi Chris
I read somewhere in a Canadian forum that the setting in the US cluster preferences changes all to kph except the actual odometer. This continues to show miles (and I assume count up in miles). Is this true? e.g. I get we can flash eprom to make the odometer show current car kms but if it continues to count up in miles it will quickly become inaccurate.
Also a lesser but annoying item with US cluster is that kph is the inside ring and the outside larger lettering shows mph. I have not found anybody selling a new facia but this guy could be asked.
http://www.blackcatcustom.ca/infiniti_g35.htm
Edited by mybrains
Thanks guys, yes CDN seems the go. In my hunt I see both Nav and non Nav versions of the speedos. Whats the difference? I would have thought the cluster didnt have anything to display nav wise (but maybe it has something to do with providing the nav system with driving info?
I have a Nav car, but am currently seeing a non Nav CDN speedo. I wonder if it will work (or can be modded to work - maybe by transferring something from my existing JDM cluster?)
I'm quite interested in changing over my dash cluster screen to display in English too, but is there any reason we can't just change the actual screen components within our jap clusters???
Or are people just changing the whole cluster because it's near on impossible to find just the actual screen itself without buying a whole cluster?
BurtoN86,
inside is pretty integrated (screen to main PCB and externally to ECU) and I doubt the lcd swap alone would work but hell, give it a go and report back.
Also the facia on JDM models only goes to 180kph whereas Canadian goes to 260kph so a facia swap wont work by itself either. Its just much easier to swap the unit whole and be done.
I scored a Canadian FX35 08 cluster a will attempt to use it in a 2010 EX35... physically looks the same but no idea if it will swap. If not, anybody with a FX can contact me for a Eng 260kph speedo :)
Edited by mybrains
BurtoN86,
Dont think the FX series were ever sold in japan under the Nissan badge thus none out there with 180km/h cluster either imo...
  • 4 weeks later...
  • 1 month later...
Ah, you're missing out on the most fun thing: learning to give voice commands in Japanese. Stinking hot day and saying "Air con ju-hachi do" gets a few laughs from the passengers. :P
I tried this today and had a good giggle. Got any more commands I can try? :D
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
