Hello Gents,
I thought I would start a discussion on shaving. A subject that is rarely spoken about yet we all do it.
Ever since the first little whisker emerged on my chin I have always shaved with multi blade cartridge shavers. However cartridge shavers seem to pull on my stubble before cutting which was quite irritating and just thought is was part and parcel of shaving.
One day I was trolling YouTube and came across a video which has changed my shaving experience. The video was about the pros and cons of the other forms of shaving:
Cartridge
Safety or DE shaving
Shavette
Straight razor
I now use a Safety shaver and have not looked back :) Not only is it a nicer shaving experience with less pulling and irritation it also works out cheaper which is a nice bonus.
So Gents what works for you? What products do you use/recommend?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/
I used to be somewhat jealous of the guys who used to have to shave in highschool. Now I'm 30 and i get annoyed that i have to shave and am glad that i can get away with only shaving every 7 to 10 days (start to look a bit rough after 7). I also don't like being freshly shaven. Sweating when freshly shaven annoys me. At least on my face. Freshly shaven legs feel nice....
And i just use a cartridge razor.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830380
Shaving wasn't one of my favourite routines but now I treat it as some kind of "me" time.
Shaving with a Safety razor takes about 2-3 times longer than with a cartridge razor, especially with me using the brush and soap.
Generally I need to go over 3 times to get the desired smoothness.
If anyone wants more info on other types of shaving check out this bloke and his videos:
http://www.youtube.com/user/geofatboy/videos?flow=grid&view=0
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830456
I am the same as you Dave. Shaving is annoying as all hell, but it is something that I take my time with and pride.
My routine uses two different razors. Safety razor first to get rid of the majority of the hair and thin it out. Reapply shaving cream with the brush and use a Gillet ProGlide Fusion afterwards to smooth it all out.
Do you use any pre shave oil?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830697
yea i towel up or splash hot water, then go over it with oil. has made a difference, feels like the blade glides over the skin easier.
i found going over the second time with the pro glide i get the smoothest shave for a couple of days.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6830947
Best shave I ever had was when I went to a Barber and got done with a Straight Razor !! Whole experience of having someone with a blade on your throat was a little nerving at first but great!
Now i just use a cartridge and foam. Considering getting a new one as my current handle is about 10 yrs old! might give a safety razor a try as people seem pretty happy with it.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831137
Straight razor shaving is great, I have also had a couple if shaves done by a barber and I could hardly feel the blade shaving along my face. One day I'll step up to a shavette shaver after I get more comfortable with a safety shaver.
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831151
I find that I sometimes get neck irritations and sometimes acne on the neck as a result of shaving, I use a multi-blade Gillete cartridge shaver with gel, I use hot water before hand and an after-shave cream.
Any suggestions?
https://www.sau.com.au/forums/topic/424282-shaving-and-you/#findComment-6831226
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
