Thanks guys. I just gotta find a way to get the power down now.......
Good luck with you build Dave! You got a thread?
Just weld her up.... She'll be right.
... as long as you only live your life a 1/4 mile at a time that is.
  • Like 1
+1 for not doing a Greg
Especially at 'normal car' levels cause that's what I did
Repeat
Do not do a Greg
Also, turbo size looks matched pretty well with the engine, great result, and I am 100% sure and would bet my life Scotty actually said "SEE MATE I TOLD YOU WOULD MAKE MORE THAN 100KW haw haw haw"
He hasn't seen it yet Greg but he will say exactly that lol.
Thanks for the love guys.
Got a new old bonnet today, changed the pads to a1rms, new thermostat an rebuilt drivers side calipers.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
