Hi all,
I own an r34 gtt and am looking for an oil to use to suit daily driving and the odd track day. I live in Perth so it doesn't get that cold over here as well. If anyone could recommend what combination would be best ie 10w-50, 5w-40 etc it would be greatly appreciated !
Attached is some oils Supercheap sell. Any recommendations on what one to buy would also be great post-135000-0-56593000-1423492571_thumb.jpg
Thanks in advance
https://www.sau.com.au/forums/topic/453695-what-oil-viscosity-to-use/
Also before anyone says search the forums I've seen lots of stuff on what brand of oil people use but not too much on the viscosity, but if someone finds a forum discussing this my apologies and could you please link me !
If you go to the track at all a full synthetic gives you a measure of extra protection.
There are lots of opinions about viscosity but I use Motul 300V 15W 40
If you have an oil pressure gauge and preferably an oil temp gauge as well you can see what works for you.
  • Like 1
For years I've persisted with using 10W-40 weight oil as I believe that's what's recommend. Using that weight I've always experienced a slight amount of oil misting out through the front of the engine (cam shaft seals etc). Several seal changes over the years and different cam breather setups never fixed the issue.
I recently changed to 15W-50 weight fully synthetic and the leaks appear to be gone.
  • Like 1
Given the usage model of your car you could realistically use just about any of those oils.
Given that Perth gets pretty hot and that you plan to do some track work and that it IS a turbo, avoid anything with a 30 rating. You need at least 40. If you tend to run the oil to high temperatures (do you even know how hot your oil gets?) then a 50 would be better.
Out of all that lot in the Supercrap listing, I would lean towards the Penrite 10 10ths or HPR10.
  • Like 1
Been using Penrite Racing 10 for 8 oil changes so far and I can't fault it.
My car runs an external oil cooler, so the oil temp is at 80° for most of the time.
Highest I've seen it get to is 100° after some prolonged spirited driving, but it gets down to 80° pretty quickly and oil pressure is stable from when it first goes in to when I change it at 5000kms. Ive been tempted to go longer between changes but its not overly expensive
Have used Motul, Mobil 1 in the past and the car feels happier. Tempted to try the Nulon synthetic at some stage also
I reckon ?W-40 is the best choice. AFAIK the only two valid reasons to go thicker are;
1. To bring oil pressure up to spec in a worn motor
2. To hack around running your oil too hot.
Instead of #2, get an oil cooler that will keep your oil below 120 Deg, and use a full synth 40.
Yeah I know but I have <2 weeks to do all this stuff to my car for the track day and adding an oil cooler isn't an option right now, but when I get the time I definitely will. And thanks for the suggestions guys. I was looking at the penrite 10w-50 oil before and I think I'll go with it for now until I get an oil cooler, then maybe I'll go for a 10w-40 oil or stick with the penrite depending on how it goes. Once again much appreciation for all the continuous help here !
R32 GT-R, 160k+ km (probably more), no oil cooler, two overheats with 5W-60 (like 130+°C oil temps), three track days. Motor sounds the same as it's always been, car runs fine :).
Ran a track day with Racing 10 as well, I think it runs better with that, but my car runs hot on the track.
Now that I have an oil cooler, I might switch back to Racing 10.
Each to their own I guess but if its a street car that is only doing the occasional track day then frankly as long as its a reasonable quality semi synth oil can you really drive a car that hard on the road that a 10W-40 or 15W-50 or thereabouts is going to be an issue?
When you do a track day, the 1-2 times a year ALWAYS put a fresh filter and sump of oil in the car. That't my practice. And frankly people saying run a cooler, keep it under 100deg....my experience is your oil temp will run over 100, more like 110-120deg c which is perfectly fine.
Remember that the oil going through/around the cams and lifters is subject to far less shear and temp and only running at half the speed of the crank vsgoing through the mains and big end so you are only measuring the average oil temp on your gauge.
The old wives tail , which seems to hold true on race cars is run the oil over 100deg c so any moisture/condensation, blow by gases etc dont stay entrained. How true that is I dont know...but of course those engines are purpose built and toleranced accordingly
So that is the BS I tell myself and every time I go to the track I always run a genuine Nissan oil filter and Castrol 10W60. I love the viscosity, rape my engine with boost and revs and havent lost a bottom end.
If you find on your aftermarket pressure guage you have 60psi at 7,000rpm with the oil up to temp with XX oil then I would be bumping up viscosity so that you are between 70-80psi
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
