If it's the turbo selection that is causing these issues.... Everything else is irrelevant. See what the new tuner says.
You're dreaming its not out of puff & i don't know how you're jumping to that conclusion?! As history repeats you can bet these blokes haven't done their job properly AGAIN! Odds are the boost control hasn't been played with properly or they have piss weak springs in the wastegates. But falling on its ass like that at 5500 isn't showing the 6262 being all in IMO pretty sure itd taper off more gradually then just drop off the planet like that. It is a 705hp turbo FFS and hes using over 500 of it currently.
  • Like 4
Thats your conclusion.
While I don't think that turbo is necessarily the best option for this setup, I tend to agree that the turbo is not the most likely cause of what is being seen. Again a shame that there appears to not be better communication from the previous tuner.
  • Like 1
how does it go starting at low temp?
Is that not the reason xklaba didn't take his?
Never had an issue. Even down at Cootamunda in the middle of winter, left outside at the hotel. That was bloody cold that morning too.
Get the tuner to do a PROPER cold start.
The problem I have is my car was tuned to in summer where the mournings are still over 15deg so setting it up for 0 deg is a guess at best, it starts 6 deg with a bit of whinding, less then 10 seconds
It just wasn't looking like starting and at 5:30am with my fuel pump I didn't want to sit there whinding for however long it would have taking to start upsetting my already dickhead neighbours
I also have cold Denso race plugs which wouldn't cold starts
Maybe, would be pretty disappointed if the workshop didn't sort that out.
And boost can drop like that if the the rear is beyond its VE especially if manifold pressures were to rise and this would obviously crack open the gate amongst other things. I still think the .82/62 rear is way too small for a 3.2.
Pete, seriously....Don't worry about all this response rubbish, just go and buy yourself a GT42 and be done with it. Rev the f@$king thing past 3000 and be happy with the face stretch when it comes on. Been done hundreds of times before and it just works.
  • Like 1
Fair enough.
Now, I need availability near my work or home.....
or, stick with 98.
I know what you mean, I would have to drive about 200Klm to get it and it would be just about 3/4 empty when I got home.
Different deal if you are doing something special with it, fill a few cans. Thats were the flex fuel sensor will come in, use it when it suites you :yes:
I so agree
I so agree
No worries mate, all good.
Had a 80klm drive this morning to get the cobwebs out, good stuff!
Take car to Jez
End thread
Yep well this thread will only ever be more supposition until the car goes to another dyno to find out what is really going on. At least if it goes to DVS Performance he can read some of the history behind it here.
SORRY, it cannot be over until the " Final Tune " after this 3.2 build is finished, so hopefully, very soon :)
Probably will not be too much KW difference but might change were it starts kicking in ?
Never heard of an external wastegate opening due to exhaust pressure tbh, I'd consider it a design issue if it did - by function definition they are meant to block any flow until the reference pressures met targets - especially if it had both ports utilised.
In regards to VE dropping, that's just going to mean boost pressure will go up for a given airflow - the 62mm hot side is proven to flow much much more than Pete's setup is asking of it... so while I agree it's hotside is way too small for that setup (.8x twin scroll 62mm on a 3.2 - what the actual f**k? I didn't realise...) IMHO I think that explanation doesn't add up. In saying that, it's making good power and if Pete is happy with it then really all that really seems to be needed is making sure the mechanical and tune situation is on point and enjoy.
Things don't seem to be necessarily optimal, but I'm not expecting to see miraculous improvements in power - perhaps some improvement in power delivery if it turns out the intake cam proves to be excessively retarded in practice.
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
