Any updates ??
Nothing yet, not sure what to expect ?
I have asked to have the cam advanced for response without worrying about what it does to the top end.
It was suggested that with my set up , it would tune close to what I want on E85 but unfortunately that would only be used when available and that would not be too often. I want it to be as good as he can get it on 98 pump?
So I will wait and see how it turns out :/
V-Cam ?
Does it ever end when you chase a dream :no::yes::no: ?????
Mercedes are so over rated, my oldman has had E and C class... the amount of times they've been in for repairs :rolleyes: he's going back to Jap built cars, the last straw was when the sunroof dislodged the whole roof limning assembly on the C230, just out of warranty too. Some of thier engines are nice but as whole they're not as good as they once were.
V-Cam ?
  • Like 1
This is where you're a bit wrong. It should read 'they weren't as good as they used to be but they've rediscovered themselves and are now awesome again. Your old man has an old model car. C230's were a fair while ago. I'm massively biased (I'm sales manager for an MB dealership) but the current product is incredible. We've got the new model C63S sitting on the showroom at the moment and it's a work of art! The twin turbos sit in the Vee of the engine and looks amazing. Everyone needs to do themselves a favour and go into a dealership just to hear one start up and rev. They have a bi-modal button that when you press turns a great sound into a sound you would happily donate your left testicle for. Seriously!
You forgot to mention how the early C63s head studs corrode and they loose coolant, and eventually do the headgaskets.
Only took 3 years for them to rectify that one...
On a serious note, yeah, they are cool cars. I thourghly enjoyed monstering a CLA45 on the track. In a straight line those little turbos are mighty impressive.
Ha ha, yeah I'm not going to say the current fleet are perfect until they prove themselves but compared to the 80's, 90's and up till 2013ish models, they are a huge leap forward in terms of styling, build quality and handling.
Our DP got to attend the AMG GT and C63S launch at Bathurst 2 weeks ago. He's not a car nut but he was amazed. Flogging AMGs at 270km/hr down Conrod straight is enough to convert any non car lover!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
