30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
We will see 100 pages one way or another dam it :rant: lol
Dont worry mate I enjoy the info while I am waiting for my job to be finished and Paul is back in action, all good :yes: :yes:
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
When did his get full boost, I will try to find it later but I do not mind maxing out under 380 kw and I am hoping for full boost under 4000rpm and think we will get it, but my expectations so far in the modifying world have been less than met, lol
Full boost at 4600rpm seems late and hopefully with the cams and cat tweaked, the 6boost manifold , a new tune???
28 psi was at 3300 I believe. That's a 6466 with a 1.00 rear.
I'm not sure about that as the dyno wasn't logging RPM. When it had the 18lb gate springs installed it would easily get to 18lb at around 3200.
To get some control though, I changed the setup to use twin port boost control with the gates and am using 10lb gate springs instead. This is bringing boost on a little slower, so probably 3500 to 20lb and I have no idea where it gets full boost as my eyes are on the road instead.
Pete's setup should be all on around 3500-3700 at most.
  • Like 1
20-22 was best results on my street tyres
Different tyres respond differently to different pressure, cause these things a 30 series they rely on tread grip as there is very little sidewall so no flex so I need to get even pressure across the tread for best traction, it also means they need heat to work and that is something I can not do in 4WD at the drag strip on a 10deg night :(
they are not the best thing for drag racing or standing starts but awsome for circiut use
yes, eyes on the road once it's on, no sightseeing , lol.
Had a bit of a look at those 6Boost Manifolds, seem like a nice unit.
Hard to find a lot of info, anyone used the 6boost or knows about them.
From what I can work out, it is the way the 6 pipes all come together and there is no real disruption of the exhaust flow ( not sure about the wording) :/
Thanks, I should have opened my PC as this laptop really is difficult at times searching on SAU, I cannot login directly or get PMs or Notifications ????
So it seems like everything, some think something is great and others think it is crap ,haha
It's to late now don't you think?
With some people liking it and others not are down to personal taste, whether they got a dodgy mani, application and a million other factors.
It is better than that Swiss cheese mani you had
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
