30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
We will see 100 pages one way or another dam it :rant: lol
Dont worry mate I enjoy the info while I am waiting for my job to be finished and Paul is back in action, all good :yes: :yes:
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
When did his get full boost, I will try to find it later but I do not mind maxing out under 380 kw and I am hoping for full boost under 4000rpm and think we will get it, but my expectations so far in the modifying world have been less than met, lol
Full boost at 4600rpm seems late and hopefully with the cams and cat tweaked, the 6boost manifold , a new tune???
28 psi was at 3300 I believe. That's a 6466 with a 1.00 rear.
I'm not sure about that as the dyno wasn't logging RPM. When it had the 18lb gate springs installed it would easily get to 18lb at around 3200.
To get some control though, I changed the setup to use twin port boost control with the gates and am using 10lb gate springs instead. This is bringing boost on a little slower, so probably 3500 to 20lb and I have no idea where it gets full boost as my eyes are on the road instead.
Pete's setup should be all on around 3500-3700 at most.
  • Like 1
20-22 was best results on my street tyres
Different tyres respond differently to different pressure, cause these things a 30 series they rely on tread grip as there is very little sidewall so no flex so I need to get even pressure across the tread for best traction, it also means they need heat to work and that is something I can not do in 4WD at the drag strip on a 10deg night :(
they are not the best thing for drag racing or standing starts but awsome for circiut use
yes, eyes on the road once it's on, no sightseeing , lol.
Had a bit of a look at those 6Boost Manifolds, seem like a nice unit.
Hard to find a lot of info, anyone used the 6boost or knows about them.
From what I can work out, it is the way the 6 pipes all come together and there is no real disruption of the exhaust flow ( not sure about the wording) :/
Thanks, I should have opened my PC as this laptop really is difficult at times searching on SAU, I cannot login directly or get PMs or Notifications ????
So it seems like everything, some think something is great and others think it is crap ,haha
It's to late now don't you think?
With some people liking it and others not are down to personal taste, whether they got a dodgy mani, application and a million other factors.
It is better than that Swiss cheese mani you had
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
