3 hours ago, Dose Pipe Sutututu said:
They spelt Samsonas wrong lol
Congrats mate, when are the t shirts being mad for roll racing? ?
Can't be outdone by @BakemonoRicer
Yes Brett is on my hit list at roll racing that's for sure, he'll never live it down when i fly past him
Brett, what made you choose PPG over Samsonas, & are you upgrading to a larger input shaft?
  • Like 1
The biggest selling point was ease of fitment but also I don’t like the massive shifter in the samsonas and like that I can put the shift boot back over the ppg. Yes it has the big input shaft, it’s standard on their sequentials
On 11/09/2020 at 5:25 PM, r32-25t said:
I decided to do a 9 plate set up in the drum for the transfer case and did the required measuring for the clearance. I only needed to go up one plate size and lucky for me Ben @BK had one in his collection and was nice enough to sell it to me
just like to say thanks again to Ben for all the advise and selling me the plate can’t wait to drive it
No worries mate, glad I could help. So a PPG sequential going in, nice one.
  • Like 1
I agree the shifter is a bit of an eye sore but it does make shifting very light and easy for a dog box.
The ppg is a quieter box and it does fit in a 32 a bit better but as with everything there are downsides at all.
Should match the single turbo well!
  • Like 1
1 hour ago, Shoota_77 said:
What sort of pool do you recommend?
Type of pool is your call, but I recommend calling it a "RFS emergency water source" to assist with approvals
1 hour ago, r32-25t said:
Above ground and when the kids stop using it pull it down and put a shed on it
Maybe the pool can be underground storage for more parts when the shed goes over the top?
Some how I missed that the box didn’t come with a speedo drive, jumped onto kudos website and a bit of money later have a brand new A9C3D6A1-06F9-4B39-A7DB-378DED05E6FF.thumb.jpeg.c5eba1144021797f67a45fbbfe6bc644.jpegthen put the transfer on the box and buttoned everything up and now the box is ready to go in the car 9D336DD4-E39F-4279-B7B3-BFF06A208057.thumb.jpeg.9e15618b7010d8408c84262dee9d0926.jpeg
  • Like 5
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
