I don't have a driveway...
Dare I organise a working bee to get this shit done? Who would properly come? It would probably have to take place at Scotty's who at least has a hoist for dat dere lower car onto engine approach.
"The Birds and the bee" - help get me back on track. Free bbq and severe amounts of alcohol supplied.
just remember to give the booze at the completion of work.
the amount of jobs we have started and had to finish next morning as we got on the piss
  • Like 1
But what do you do when a rumour starts that the ecu is considering a transfer to another vehicle and neither denies nor confirms it?
Ask the ecu to draft up a role description & put out a feeler to find a piggy-back to take some of the load.
  • Like 1
What's your assembly PB?
I guess we could try for some sort of time setting record; that sounds like me to choose hijinks over getting the job done properly
no shit, im f**king great at pulling shit apart but no good at putting back together, which is why you have miguel and sir odium. those dream boats are f**ken guns.
we could even kidnap borci.
Is there such a thing as too many hands? I see a lot of drinking and hardly any work getting done, or having to ask 8 people where an unlabeled part is because we tore the engine apart zombie horde style lol
The more people present the less accountability per team member. Which can result in a bigger pisstake for something which needs to be taken seriously lol
Looking forward to the Sandown day in January, do you know when we need to register by / when/if it will become full?
Just ordered a new bodykit which is getting painted next week. Time to upgrade the brakes, exhaust and wheels next month as well :cool2:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
